Guest
Posts: n/a
I have a 1987 911 Carrera Coupe and I have a 24mm nut. No issues getting it off as I have the tool and a 24mm Wrench. However, I only find 4 Shims installed. Is the 24mm size an indication of an aftermarket Alternator that might require only 4 shims? Or do I need to make certain to use all 5? I had ordered new ones anyway to replace the old in case they were too worn
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 911 Fan Belt and Pulley Replacement |
Author of "101 Projects"
Yes, you always need to use five. Whether there are four on the inside and one on the outside. This is a common misunderstanding and a cause for lots of engine failures when the fan belt slips off. Use a total of five all the time, but not necessarily all together (some on the inside, some on the outside). You need to move them from the inside to the outside and/or back to make the belt tighter or looser.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Hmm...isn't it six shims total?
ROW '78 911 Targa
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
shims.
It is six.
On our '86 I used two shims between the pulley halves, and four in the cup. Good luck, Gerry ![]()
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 12-18-2011 at 04:03 PM.. |
Wayne, are you messin' with us? How does a guest (Fonz) start a thread, and then you respond with an answer (that I assume took more than 1 minute to type) with the same timestamp....enquiring minds and all that
Time machine......
He who controls the server controls time!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Not really. If you post a question on the technical pages it auto generates a new post here as a guest. Wayne probably gets an email and simply responds which gets posted here too. Read the bottom of the posters first thread.
Matt. 83 911SC 85.5 944 NA - Sold |
83 911 Production Cab #10
and another 10 between 0330 & 0400PM, make that about 20 between 0258 & 0400PM Wayne has been busy
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 12-18-2011 at 06:12 PM.. |
By the way those shims are very thin. I change my belt for the first time earlier this year. I did not realize one dropped down into the belt shroud. I got a bit confuse after having read that six were needed. Sure enough looked around with the flashlight and spotted the one that fell , I guess when I took the pulley off.
Something I find to be very helpful for this job is to use a bit of tape to hold the 3 or 4 outer shims together. I use masking tape and as little as I can, wrap 2 tiny pieces around the washers to make in a way 1 super washer if you must. I find this helps to get the washers to sit on the shaft the right way and also helps to keep them from falling.
Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
![]() How many alternator pulley shims on a G50? Last edited by KFC911; 12-18-2011 at 09:35 PM.. |
Maybe, just maybe a malcontent HAL90000 took over the database and is generating the answer ![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
