Another rear sway bar question
I have a broken rear sway bar mount (imagine that) on my '76 911. I have decided to go with the WEVO consoles but here's the rub: I need to update the bracket and bushings. I have a 19 mm sway bar, the updated bushings are for a 18 mm bar.
I also have in my spare parts a later 18 mm bar and brackets (from an SC) so I'm good to go for brackets. My question is which bushings do I need to fit the bar to the consoles. I know which ones will fit the bar to the drop links.
Any input is appreciated. I'll take pictures if needed.
Old 01-16-2012, 04:26 PM
So here's a pic of the worn 19mm bushing and the "later style" 18mm bushing. note the shape at the bottom of the later. That's what I believe to be the difference.
Am I overthinking this?
Old 01-18-2012, 07:05 PM
WEVO Sway Bar Bracket Install mod
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-18-2012, 10:46 PM
Thanks Ronnie, I had already read your post. Good info there for sure.
Still, my concern lies with which bushings to use. I already have brackets that will work. If I buy bushings for the later model to fit the consoles and brackets, They are for the 18mm sway bar. Can I simply install those on my 19mm bar and clamp them down?
Old 01-19-2012, 09:38 AM
Bird. It's the word...
Fishcop's Avatar
You need to buy bushings specific to the diameter of the bar you're using (the bracket size remains constant)... If you use a 18mm bushing on a 19mm bar you're likely to get binding and noise.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 01-19-2012, 03:03 PM
I am now wondering if the sway bar on my car is original.
Is a 19mm rear sway bar standard for a 76 911?
The front bar is 20mm
My spec book says 16mm ft and no size is given for rear
except turbo and carrera 18mm
the bar is silver (mostly rust colored)
I can find no identifying vendor code on the bar.
Old 01-19-2012, 04:27 PM
Fishcop's Avatar
Hard to say... But I'm pretty sure Porsche spec'ed a larger rear swaybar than on the front as "oversteer is preferred"
John Forcier
Old 01-19-2012, 05:42 PM
So It seems a bushing is not available to fit my 19mm sway bar to a WEVO mount.
I guess I'll have to fabricate/modify.
Old 01-22-2012, 04:37 PM
