Free factory steering wheel Bushing
Good work Harpo!
Those round head bolts are shear bolts. I don't know this for sure, but I presume the factory used these to assure the steering system was torqued correctly with evidence. The bolt heads shear at a known torque. I decided to leave mine in there and did the bearing replacement in situ. Was your column painted black originally? It looks nice black! |
Schleprock
Tom,
I think the shear bolts are an anti-theft measure? The ignition lock has similar, but smaller, bolts with heads that also twist off when fully tightened.
Kevin L '86 Carrera "Larry" |
Good thought. I pity the fool who steals a car with the steering wheel in his/her lap.
www.ahhgaragetime.com |
Just seemed like a good idea to paint it black
Lash
Just finished replacing the bushing. Noticed a few weeks back that suddenly I had vertical movement in the steering wheel. Easy job, no issues but it took me about a half hour from start to finish. Thirty seven year government man I work slow and take breaks.
Lash Lash ![]()
Old, old thread but wanted to say thanks to KTL for the small vice grips idea. My 86 had a loose steering column and thought I was doomed with the three shear bolts holding it in (albeit, loosely) and found that they actually can be tightened, or removed, with small vice grips. Tightened down and play was removed! Thank god for these old threads! Erik
1986 911 Coupe 1986 911 Targa |
Schleprock
Glad to see the info I shared was helpful. The mini vise grips are a great rescue tool. Whoever invented vise grips is a godsend. Thanks for the thanks!
Not to hijack the thread, just had a related question--my steering column had been messed with when I got the car. The turn signal cancellation was removed and the bushing was a bit crumbled.
I replaced my bushing with a rennline one, but I have not been able to figure out what the snap ring is for. Mine fits loosely on the groove, and removiing it or leaving it makes no difference. My steering wheel does make a friction sounding as something is rubbing so I was wondering what the purpose of that snap ring was. Thanks!
1987 Carrera 3.2 coupe 2014 R55 Clubman S |
Schleprock
The snap ring/circlip acts as a stop for the steering wheel hub
I happened to have a spare steering column assembly on the shelf in my basement and checked the fit of the steering wheel on the column shaft. The wheel hub is definitely stopped by the circlip ![]()
Schleprock
But honestly the steering wheel hub is also stopped by the end of the shaft where the splines end. The shaft is larger diameter there, so the hub can’t go any further. I think the circlip just prevents the hub from damage when you tighten the main nut for the steering wheel? Because without the circlip, the hub could push past the end of the male splines on the shaft? I’m not entirely sure on that belief because I didn’t take any measurements
Thank you Kevin, that makes complete sense now that I see your picture. I have a Momo hub and it makes a slight grinding noise as I go around, and the clip itself is deformed. I had put grease on that point but now that I've seen your picture I will try putting a new clip on and see if that sorts it all out. Thank you!
Good stuff! Who would have thunk' all these years later...KTL (Kevin) is still answering such unique questions...If you are ever driving through Missouri first drink is on me! Nicely done sir! Erik
Schleprock
![]() Ain’t dead yet. Still rolling along in life but not able to play with the car like I used to do. Life DEFINITELY gets in the way for me much more than it ever did years ago! Maybe someday I’ll find some time to get back to reassembling my eternal Humpty Dumpty project in pieces all over the garage & basement?
Well, your vice grip advice got me from Weston, MO to OKC for the Porsche Parade. I even removed the HVAC to check on everything and knew it had to be those 'damn' bolts. When the first one turned a bit with some very small vice grips I knew I had learned something new that day... Keep on Truckin' my friend! Erik
