Formerly reformed
Is it just me, or is this thing crooked?
Torsion tube. This was taken before I blasted the car in '06. Just noticed that it seems to be listing a tad. It was cut from the car years ago . . .
1968 911P (Paperweight)
Old 02-24-2012, 09:11 PM
RETIRED
Joe Bob's Avatar
Looks twanged to me....but I drink a lot....
2012 ML350 3.0 Turbo Diesel
Old 02-24-2012, 09:17 PM
Member 911 Anonymous
DRACO A5OG's Avatar
LOL JB
Well, to be certain, take measurements, pics are deceptive due to angle/shadows.
'85 Carrera Targa
PCA/POC
Old 02-24-2012, 09:22 PM
Max Sluiter
Flieger's Avatar
The dent helps it clear the transmission, and is supposed to be there, if that is what you are asking.
Old 02-24-2012, 10:45 PM
Honey Badger
theFONZ's Avatar
It did at first, but then I noticed the corrosion on the lower left side, so it's hard to tell.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 02-24-2012, 11:39 PM
TDIDog's Avatar
The left side torsion tube looks lower than the right in relation to the rear seat bottom. To me.
Old 02-25-2012, 12:08 AM
Old 02-25-2012, 12:20 AM
muck-raker
kidrock's Avatar
I'd take measurements and/or stick a level on it
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-25-2012, 02:21 AM
Hodgey's Avatar
think it might be the angle of the dangle from which you shot the pic
Neil
1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic
(X) [B] 2011 BMW X5[B]
'Success is not final, failure is not fatal. It is the courage to continue that counts'
Old 02-25-2012, 03:51 AM
Carmagic.us
rothaus's Avatar
Either the left side torsion tube is lower, or the right rear seat bottom is higher, or both.
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 02-25-2012, 05:25 AM
brooklyn ny 11234
930 slant nose's Avatar
you sure the floor is straight
Old 02-25-2012, 05:39 AM
Max Sluiter
Flieger's Avatar
There are too many variables to tell from a handheld photo. You need to get the car on a celette.
Actually, just put a straight edge up to the tube. Run it along the tube and on different lines around the circumference and on both sides. You should be able to tell if there is a bend in it that way- there will be a place (or places) where you cannot get the straight edge to contact the tube along the entire length of the straight edge no matter at what angle you position it.
Old 02-25-2012, 09:50 AM
Banned
Will be pretty difficult to assess with any tool at all considering he said it was "cut from the car years ago"!
Old 02-25-2012, 10:10 AM
Max Sluiter
Flieger's Avatar
I missed that part.
So why does he care if it is crooked? He must still have it then. In which case he can use a straightedge.
Old 02-25-2012, 10:17 AM
Formerly reformed
It's on a jig now. It's actually BEEN on a jig for a matter of years now and still refuses to fix itself.
So we're not on speaking terms right now.
Old 02-25-2012, 01:40 PM
Zeke's Avatar
Just saw this thread. It's definitely not right. But, given the make over you are doing, does it matter? Even if you were restoring the car, a corner balance would cure all but the last enth of a degree of alignment throughout the suspension travel.
Old 04-04-2012, 01:03 PM
