Porsche Crest Where can I get some of these connectors.
I need some connectors like these. I really need the big red one in the corner. Does anybody know were to get them. Thanks.
Old 05-08-2011, 04:04 PM
Retired Member
Brian 162's Avatar
I believe our host sell them. I purchased the 14-pin connector a couple of years ago. If you can't find it online try phoning and ask for Jason. He is the guy for the older 911's.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 05-08-2011, 05:34 PM
Almost Banned Once
sc_rufctr's Avatar
Porsche 911 & Carrera Gauges and Miscellaneous - Page 6
- Peter
Old 05-08-2011, 05:47 PM
Thanks.
Old 05-08-2011, 05:52 PM
mechanic by night
It appears the pins supplied are the "male" pins. Anyone know where to source the "female" sockets that live on the engine harness plug?
76 911 "The Blond B_ch"
(what the wife calls it)
09 Mazda 3
06 subaru legacy spec B
91 track miata
Old 12-20-2011, 01:32 PM
m110's Avatar
911/964/993 Restoration
call them
bring visa
1988 Carrera Coupe
Old 12-20-2011, 07:33 PM
mechanic by night
I have been there before, with visa. Apparently concerning the 14 pin connector only the male pins go bad. There is a joke in there somewhere. Actually I would like to add a female socket to make use of a previously unused male pin. The pin is a switched 12V into an empty socket on the engine harness side. All in a quest for neatness.
09 Mazda 3
91 track miata
Old 12-21-2011, 06:02 AM
mechanic by night
The male pins are roughly 1/8 inch. Any tube guys still out there? I know some vacuum tubes still exist so what about sockets. Were or are tube pin sockets different sizes? I aint young but this is still before my time. Any thoughts?
The sockets exist on the car in otherr capacities. Examples: round relay pin sockets (at $70 a shot I will find another way), the fuel level sender plug, two plugs at the aft corner of the engine compartment (tail light connectors?). I am sure there are others.
09 Mazda 3
91 track miata
Old 12-21-2011, 01:19 PM
KTL KTL is online now
Schleprock
KTL's Avatar
I have pulled a bunch of useless wiring out of my racecar. I can look thru what mangled stuff I saved and see if there's a female cooch in there for you.
Kevin L
'86 Carrera "Larry"
Old 12-21-2011, 01:33 PM
mechanic by night
No need to do that I will follow a different path. I wanted to use an unused pin on the 14 pin connector for an Ignitor II install. Would have made, I think, for a very neat switched 12V supply for the new device. I could have laced it in and in the event of a return to points it could have been left in place. I am attempting to follow the self imposed "porsche-cratic oath" where the main rule is "do no harm to the factory harness."
I think I've got it figured out. One of those deals where my vision and reality diverged a bit.
09 Mazda 3
91 track miata
Old 12-22-2011, 02:46 AM
76 911S Targa
Finding a Porsche in a wrecking yard is unlikely (I always ask and I haven't found one yet), however, there are plenty of Mercedes, Audis, VWs and Volvos that can be salvaged for electrical connectors. Take along your wire nippers and cut out the plugs of your choice. They often are similar if not identical to those used on our cars.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 12-22-2011, 08:13 AM
bart1's Avatar
I don't know what those are called right off, but I bet Jameco has them.
Jameco Electronics - Electronic Components Distributor
However, this thread is giving me flashbacks of a painful ignition switch project I had.
Old 12-22-2011, 11:47 AM
I have both but they are not cheap. They are quickly becoming unobtanium.
Please contact if interested. WGHowardIII@Gmail.com
2016 GT4
Old 12-22-2011, 11:51 AM
mechanic by night
What I am going to do is connect to the lower fuse "block" in the engine compartment. It would also be nice to have some of those tiny crimp sleeves that the factory terminated the wires with at the fuse screw block. I have found something that will work for a termination and I will add a connector to keep the entire engine harness "disconnectable" i.e. not hard wired, for the next time I find it necessary to drop the engine.
I will do no harm to the factory harness but the installation will not be as "slick" as the concept idea. I haven't counted but I am sure to be at revision H or J by now. Normal for my projects.
09 Mazda 3
91 track miata
Old 12-22-2011, 12:13 PM
