Speedometer cable issue, why does this not fit 915?
Hi,
I have a slight problem when installing my engine and trans into my 1973 T Targa. The speedometer cable does not fit into the 915 gearbox! The gearbox is said to be a 1974, the car is a 1973 and I believe my speedometer cable is from my 1972 911. The problem is that the gearbox has a square shaped speedometer drive, and the speedometer cable has just a flat slot in it.
Could anyone please tell me what part is wrong or what I have messed up? I am somewhat tired today....
Thabks,
Johan
-14 Cayenne S Diesel, DD
-92 964 C2 convertible, RS -92 look and feel😃
-73 T US MFI Targa, restored
-70 T Coupé Hot Rod, painted waiting for assembly
-72 T Coupé, US numbers matching under restoration
Old 12-26-2011, 10:13 AM
Anyone?
Please let me know.
Thanks,
Johan
Old 12-30-2011, 01:02 PM
Send a message via Skype™ to Porboynz
Johan, I can confirm that the 1972 cable is designed for a flat blade shape drive as per the following picture of the speedo drive from my 1972 915 gearbox. If your 74 gearbox has a square drive then you have 2 choices, replace the cable with a later 74 version or replace the drive gear. The cable change sounds easier, maybe just needs a change to the inner if the outer large threaded connector is the same for the 72 and 74.
Maybe its possible to turn the blade into a square with a die grinder, but thats a one way process and I bet its hardened steel.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 12-30-2011, 10:36 PM
Thanks, I apprecitae your input! What made me confused was that pelican sells one for 65-73....
Now I know that thy could differ. Now I just have to rder the right one. Great input!
Thanks, Johan
Old 12-31-2011, 12:18 AM
never seen a square drive off the trans. maybe you have a section of the old cable still on the trans.
206 637 4071
Old 12-31-2011, 06:26 AM
