timing my engine...
Hello all.
In timing my engine (74 2.7), my pulley has a 5deg ATDC mark on it. I assume this is correct for my year even though it did not come factory with a smog pump.
My question is, the idle timing adjustment, is this adjusted with the vacuum hose connected or diconnected? I have heard both.
I am used to small block Chevy's where you disconnect the vacuum advance for the timing adjustment.
Also, to adjust mixture, which way to turn allen key to lean the mixture (CIS)?
I need to get a CO analyzer to set my mixture. What is the peoples choice for a stand alone analyzer?
The car stumbles a bit when I drove it around the block. This was the first time driving this car since the complete rebuild. It seems to be really rich. Pulled a plug tonight and it looked wet. Mostly tan to dark brown on color.
Hopefully I can figure it out so I can drive this machine soon.
Thanks for all the help!
Chris
Old 04-03-2002, 07:49 PM
marcesq's Avatar
Chris:
I plugged my vacuum line permenantly and set the timing to Z1 (TDC) @ 900 RPMs. Runs like a scalded dog.
If your car has a CDI unit make sure that the points are set to spec or .001 over.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 04-03-2002, 08:01 PM
thanks for the response. Any other info?
Chris
Old 04-03-2002, 09:12 PM
Cool
I'm w/Marc...I set timing at total advance. I have a cheap/weekend wrench gas tester...R
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-03-2002, 09:48 PM
Early_S_Man's Avatar
Don't you guys ever pay attention?
http://www.pelicanparts.com/cgi-bin/vb/showthread.php?s=&threadid=5432
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-03-2002, 10:48 PM
Cool
Warren...benign neglect..It is a very great thread, IMO. I think a classic is something/thread that doesn't have to be written again....still working/figureing the E-cam drama....... R
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-04-2002, 01:36 AM
