Throttle bellcrank question
On my 86 Turbo's throttle linkage, the ball and socket on the trans end, as well as the on the way up to the throttle blade, just pop off with a little pressure.
However, this one doesn't seem to want to budge. I've put more than enough force into prying it that I now wonder if there is somehow something holding it on. There is a little wire wrapped around the bottom of it that almost seems like safety wire, but I can't see how it works.
Anyway, any words of advice? Is there a trick, or just more force till ip pops off?
Ken
1986 930 2016 R1200RS
Old 12-30-2011, 02:30 PM
rsscotty's Avatar
You can see the safety wire clip that goes around the throttle rod end just behind the ball socket. This clip wraps around a groove in the rod end. Use a small screwdriver to pop the clip out then lube the ball socket and pry it off with the open end of a 10mm wrench. Sometimes they are rusted and don't come off so easy. It would be easier to visualize if you could see a clip by itself.
Old 12-30-2011, 02:54 PM
rsscotty's Avatar
I found a picture.....
Old 12-30-2011, 02:58 PM
Thanks for the reply! Mine isn't entirely intact now that I look at your picture. But that's the answer.
Cheers
Ken
Old 12-30-2011, 03:08 PM
Grappler
Rodsrsr's Avatar
Anyone know where to get a replacement clip?
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 12-30-2011, 03:15 PM
900.169.014.02 Its also used under the accelerator pedal on many cars before the beginning on the engine in 1984.
Bruce
Old 12-30-2011, 04:17 PM
Grappler
Rodsrsr's Avatar
Thanks Bruce! The wealth of information on this board never ceases to amaze me.
Grappler
Know Gi / No Gi
Old 12-30-2011, 05:17 PM
Thanks for the part number but holy crow, 15 bucks ! Ah, Porsche....
Old 12-30-2011, 06:09 PM
A friend of mine made one from a safety pin
Ned Nyna 11
87 Carrera Targa
98 528i BMW
2004 Jetta 1.8T
Old 12-30-2011, 06:57 PM
Walt Fricke's Avatar
I googled around when looking for these ball joint assemblies, and found a family owned business which does just about nothing else. All different sizes and types, metric and inch, etc.
I bought a couple of extra pins, and remember thinking they were awfully expensive for how little they are, but not $15 each! I suppose it is the difficulty of bending spring steel wire to a fairly precise shape which justifies a hefty premium over some hardware store cotter pins and the like.
Old 12-30-2011, 07:29 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Originally Posted by gsxrken View Post
I posted a thread on how to replace the metal bushings on the piece.
You must insure the pivot is parallel to that arm, if in an angle like in your pic it will never come off without damaging the part/s, it is design not to pop off on an angle.
Hope this helps.
Jim
'85 Carrera Targa
PCA/POC
Old 12-31-2011, 11:03 AM
