My version of headlight relay kit
I chose to make my own headlight bypass relay installation.
It is in and seems to be working fine. I can post material info. if people are interested. Thanks to JWest for the Posi-Lock connector tip. I got some from Napa. Here is my wiring layout, somewhat following the routing used, I put as many wires behind the fuse panel face as possible, it is getting a bit packed in there. I used relays with diodes. The most difficult part was selecting and properly crimping the terminals that clip in the socket. My Porsche mechanic loaned me a very good crimper tool and I was getting good crimps after some practice and adjustment. Get more wire and spare terminals than you need. There is crimping info. on the web on open and closed barrel terminals. ![]() |
French Import
Nice diagram. I definitely would like to get the list of materials. Thanks!
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
sudo apt-get purge 930
Or you can just buy the entire kit from Pelican for a mere $25. Comes with everything you need.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Member 911 Anonymous
Check the voltage at the head light, that will tell you if it was a success or not. It appears correct, good job Brother
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
French Import
Thx. @zippy, here is the diagram with notes on material info. and where to purchase. You will need various other items: shrink tubing, wire protective covering. Tools: soldering iron/etc., crimper for open barrel ($$$), crimper for closed barrel connections($). I would look for a relay without the bracket, it might look better. I wanted a relay with diode and they are a bit harder to find. I wired the socket to accept the standard normally open relay using 87 and 87a termination points. I have 3 other cars to do and they will get a better install than I did for my car. I'll post a picture of the final result if wanted. You will need a piece of AL or other material to mount the sockets. Also need various metric nuts/bolts/etc. Learning how to make a good crimp is not trivial. If doing this over I might consider getting the next size up wire insulation thickness. The Kayjay Co. had good info. on wire type/etc. If you get wire from Kragens it might not be the type that has cross linked plastic. I cut off the insulation that comes with the ring terminals and used shrink wrap, it looks better, more like factory. You want good quality ring terminals, that have been annealed. The ones I got from Napa had actual model and company markings, so I think they were made in the US. Lots of parts out there come with no markings for obvious reasons. ![]() Terminal ![]() You can see where two crimps are made: 1-wire 2-insulation It is hard to get these to be right, but can be done. See if you can borrow a good tool. |
Let me know and I will come over show you how to rig it up
French Import
Jim, you're on!
French Import
I will use shrink tubing and try to attach to an extension of my new fuse panel from Fred Cook. I'll even try to color match the tubing. ![]() I should have all the tools for the job. Just waiting to have my carport finished before I can get started on the car!
I did find shrink tubing companies that have offer a variety of colors and will even dye to match. I ended up using black, the red I had wasn't big enough. Take your time to figure out re. routing and figuring out what operations (solder or crimping) need to be done in the car. Do all that you can out on the bench. Consider what you end up with when viewed in the future by new owners or yourself after you forgot details of the design. The posi-lock connectors are a big help as they are easy to do in the car working with short wires. You will have to cut off the ferruels for the 4 wires feeding the high and low bulbs. I don't know how my solution compares to JWest $25, any comparison details might be interesting to others and myself. Any tips to improve my solution are welcome. I wasn't going for low cost, IMO the cost of materials is not that important, getting the best quality solution and understanding was the target. For me the fun was reading about relays, relay options, wire types, wire current carrying capability, terminals, crimpers, and crimping quality/etc. The design of a wire harness is not trivial in my opinion, there are a lot of variables not commonly thought of.
I borrowed a Tool Aid crimper that looks something like this. You need to confirm that you have the correct die set.
You might want to invest in a complete crimper set that also does WeatherPack and spark plug wires/etc. then you are pretty much covered. I had to do some pre-bending of the insulation wings to get a semi-clean looking insulation hold. Look under Molex info. for what to look for and do's don't's on open barrel crimping. ![]() This is the sort of what you want the final crimp to look like. You should be able to pull with 30-40 pounds without coming apart. The insulation should be held tight but not cut, you should see wire only between the two crimping sections and there should be a brush visible at the end but not intruding into the ring area. For added security you might consider putting a bit of solder near the brush area, but you don't want solder going past the wire crimp section. If the crimp and all materials are proper this should not be needed. I covered the crimp area and down the wire a ways with heat shrink tubing. I recommend cleaning with alcohol if any soldering is done. ![]() |
nice crimper et al
any suggestions on brand and pn or just look at amp tools? thx
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
MBruns for President
I use marine terminals - especially the ones that have the adhesive lined heat shrink connectors.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
R&D guy
Location: the border between the states of inebriation & confusion
I know it will probably be expensive, but to replace some of the older manual crimpers we have in the lab at work, it would be worthwhile. Most of the time, the cable harnesses are mass-produced using powered crimping equipment, but occasionally we have to make specialty cable assemblies, or perform some repair work. Last edited by dw1; 01-02-2012 at 05:42 AM.. |
@dw1 - since I borrowed the tool I don't have where it was purchased. If you google Tool Aid, or open barrel crimpers all sorts of links come up. If you can't find let me know. I think even Amazon has it. Found it - Amazon.com: S & G Tool Aid 18920 Ratcheting Terminal Crimping Kit- 5 Piece: Home Improvement
I was looking around and ran into this crimper which looks like many others but apparently works very well on a wide range of open barrel terminals. I like that it doesn't crimp the insulation at the same time giving more control. If you want a full set for your lab. you may want something with more dies as above. ![]() This is where you can buy that crimper and also the Hozan tools. This site has some good info. and they know about crimping. Apparently they offer a wide variety of good quality terminals. Name Easternbeaver.com It appears they have access to the good material available in Japan, remember when things were made in Japan? I digress. Tools, Open Barrel Crimpers, cheap worldwide shipping |
Alps Adventurer
Taking it one step further again, the headlight voltage should be the battery voltage. If not, the wire gauge is undersized and/or the relay is. |
Alps Adventurer
Usually I just use miniature needle-nose pliers to fold the tabs over and then solder the exposed tip of wire to the terminal. I've done so with all of my Molex connectors. |
We are planning to take some before and after volt readings for the next car converted. Last night we were getting 0.850vdc drop from the battery out to the bottom of the 3,4 fuse locations with the low beams on and engine not running. The volt meter or battery is now suspect as we got some low readings for the battery when not charging or loaded. I'm now not easily able to compare on my car as the wires are "covered".
The volt drop for the relay and wire assuming perfect termination and connection can be calculated using charts/etc. on the web and relay resistance info. My goal was to get the current out of the dash switches - if I get brighter lights that's fine also. |
I agree re. putting some solder on the tip, should not be an issue of making the wire stiff if the solder doesn't wick down into or past the insulation section. |
Thread Tools | |
Rate This Thread | |
