Czar of C.R.A.P.
Porsche door thud
I now know where the porsche door gets it classic sound when closing.
I have been stipping my doors to lighten for a race door. Removed the glass and all the regulator system and still the door had the classic thud sound when it closed. Last night I decided to remove the sound pads from the inside bottom of the door. The had become pretty stuck and brittle so a little heat from a heat gun and a razor scraper and they came right out. Now however the doors when shut sound completely different just like any old car door. So there you have it the door sound appears to and effect of the dampening pads.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Max Sluiter
I always thought it was the latch mechanism. Even after slamming my fiberglass doors I can still hear that "chiink" of the latch resonating for just a second after the bang of the fiberglass.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Chain fence eating turbo
I thought it was the combination of the beefy door latch and the fixed window frame.
A '57 Chevy has a similar sound with an added "blap" due to the SS, water flap thingymabob that closes over the window frame when you close the door.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Anti-resonance bituminous pré-stuck pads.
Used also in your bathroom.................under the bath, stuck on it.
LIGHTER = FASTER !!! |
I know this is not the right forum for this comment, but, the 356s have a rubber damper in the middle of the fender that makes that sound.
AutoBahned
yes, replace with butyl if you want to replace
