minoclan's Avatar
Is anyone running 225-50-16 tires on all four wheels?
I am putting RS flares on my 1970T. I have been toying with going to 17" wheels just because of 16" tire availability. I decided to stay at 16" with a 1.25" spacer in the rear. It seems that the number of tire choice opens up significantly if I use the 225-50-16 size on all four corners. I am using 951 7 and 8" Fuchs. I was wondering if anyone else had done this and what the result was.
2007 GT3 Red, 2008 Cayman S Track Car, 1970 911T Tangerine, 2019 AMG E53 4, 2020 S450 2019 F350 King Ranch
R Gruppe Member #626
Old 01-16-2012, 04:01 PM
WUNDERWAFFE
JINKATIN's Avatar
I've got 225/50/15s all around. I like it, I have had no issues.
Charlie
1986 Carrera
Old 01-16-2012, 09:38 PM
WUNDERWAFFE
JINKATIN's Avatar
Here is a pic of my baby with 225/50/15s
Charlie
1986 Carrera
Old 01-16-2012, 09:59 PM
minoclan's Avatar
Great looking car
Old 01-16-2012, 11:42 PM
WUNDERWAFFE
JINKATIN's Avatar
Charlie
1986 Carrera
Old 01-17-2012, 01:14 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Works good. I ran 225's on 7s all around and also 8s all around.
Here's proof that your car won't burst into flames and kill you if you don't run the staggered wheel/tire sizes that the braintrust at Porsche originally specified for the car ('87 in my case).
Octoberfest BHF 10-6-07 - YouTube
I used 930 spacers to fill out the rear fenders. Note that the 8 I used in the rear was a 951 offset 8. The 911 offset 8 is a bit too much outboard for a 930 spacer
Kevin L
'86 Carrera "Larry"
Old 01-17-2012, 02:10 PM
minoclan's Avatar
I have 951 offset 7's and 8's. I was going to put 225-50-16 on all 4 wheels with 1.25" spacers in the back. Sound ok to you?
Old 01-17-2012, 04:54 PM
Wash. State
nesslar's Avatar
At least they could be rotated properly! I like the idea in that regard, with spacers, but then, I like the fat meat from the rear view...er...on/under the car, only, I mean, I'm sure, of course, well, you know what I mean, Holy cow......what have I said.....
Old 01-17-2012, 06:41 PM
ROW '78 911 Targa
timmy2's Avatar
Far too much to ever get it back....
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-17-2012, 07:00 PM
Wash. State
nesslar's Avatar
Old 01-17-2012, 07:04 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Depends on how much room your new flares give you. I ran 245/45 Michelin Pilot Sport Cup on the 16x8 rear with a 930 spacer and it fit fine. My 245 tire is a bit wider than your 225, but my wheel had a bit more offset (it was a +28mm o/s BBS RS wheel) and the 930 spacer is ~0.15 in. thinner than 1.25 in.
This wheel info, courtesy of Bill Verburg and other contributors, is a good reference to get an idea how the wheel will move in/out with offset differences or spacer installation
http://members.rennlist.com/1976c38/index.htmlhttp://members.rennlist.com/1976c38/index.html
Are you using wheel adapters (they bolt onto the existing wheel studs) or using longer studs and slip-on spacers? The only reason I ask is because I used 72mm studs with my 930 spacers and just had enough thread engagement with steel lug nuts. If you were to use thicker spacers with 72mm studs, I don't think you'd have ample threads for the lug nuts.
Kevin L
'86 Carrera "Larry"
Old 01-18-2012, 04:07 AM
minoclan's Avatar
I am using an adapter
Old 01-18-2012, 04:26 AM
