Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
Minimum toolkit to carry ?
Just realized i dont carry any tools - apart from mix key - in the p-car.
What do you recommend as a minimum set to avoid being stranded too easily ? CIS car.
Old 01-08-2012, 07:57 AM
RETIRED
Joe Bob's Avatar
Typically what's in the tool kit supplied by the factory, plus whatever you think you might need.
I'm sure others will chip in with comments....
fan belt, with tool for whatever engine you have to keep fan from turning
open end wrenchs, 8,10,12,13,15,17,19mm
spark plug wrench...the factory one is best, ratchet
plugs
points if you have them
zip ties
flat and phillips head screw driver
fuses
lug wrench
flat plug repair or fix a flat (not a fan)
allen wrenches
tire inflator
test light or meter
electrical tape
dykes
crescent wrenches
pliers
cell phone, prepaid towing card
just off the top of my head....
2012 ML350 3.0 Turbo Diesel
Old 01-08-2012, 08:20 AM
John W
Don't forget the spare DME relay.
John
89 3.2 Targa 123k miles
Old 01-08-2012, 08:36 AM
ivangene's Avatar
how long of a trip.....
normally I carry a cell phone....seems to work OK
Ed M
86' Coupe
Old 01-08-2012, 08:37 AM
Banned
Apart from the inflator, the cellphone is the only thing i bring...
Thanks guys
Old 01-08-2012, 09:14 AM
78 in a '71
mossguy's Avatar
plugs
zip ties
fuses
lug wrench
allen wrenches
tire inflator
test light or meter
electrical tape
dykes??
crescent wrenches
pliers
Really?
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 01-08-2012, 09:17 AM
RETIRED
Joe Bob's Avatar
Women with comfortable shoes?
I would also add jumper cables....
Old 01-08-2012, 09:27 AM
5String
What Joe Bob said. I don't carry Allen wrenches or a test light, but I pretty much carry everything else on his list, plus a pair of mechanic's gloves, a flashlight, a fire extinguisher and a couple of mechanic's rags.
Most important components? Cell phone and AAA card, I should think.
Re the question mark after "dykes," that's a reference to diagonal cutters, clipper/pliars referred to as dykes. But you knew that, right?
5String
Tell not a soul that you have seen me; breathe not a word of what I say....
The Northwest Files
Old 01-08-2012, 09:29 AM
RETIRED
Joe Bob's Avatar
No DME....CIS.
Old 01-08-2012, 09:32 AM
78 in a '71
mossguy's Avatar
5string, That's a new one on me. I've only ever heard them called diagonal cutters. Maybe at one time I heard them called dykes and forgot. There's a lot of that (forgetfulness) going on here for me these days.
On glide path......
1971 911 T Targa
Old 01-08-2012, 09:34 AM
AutoBahned
RWebb's Avatar
dykes = a type of cutting pliers
throw away the certain-to-maim Bilstein post jack and put in a scissors jack and handle from a 944
put a piece of plywood in the trunk in case you have to jack the car in loose gravel or mud
in many parts of the Intermountain West a cell phone is useless; depending on where you drive you may need to carry a few days water, food, and a sleeping bag to survive until another car comes along
search on the many other tool threads to find the one that is on "minimum" emergency tools
Old 01-08-2012, 12:52 PM
RETIRED
Joe Bob's Avatar
I believe that Dykes are a contraction of DIagonal Cutters ....from a wiki article.
They are actually "diagonal side cutting pliers", basically wire cutters.
"Diagonal" is shortened to "diags" which then gets pronounced (or mis-pronounced) as "dykes"
Old 01-08-2012, 12:56 PM
RETIRED
Joe Bob's Avatar
While a good idea on the scissor jack....I try to repair the tire with a plug and re-inflate w/o having to remove the wheel. That skanky space saver is the last resort.
Old 01-08-2012, 12:59 PM
AutoBahned
RWebb's Avatar
oh yeh - space savers - I have a full size spare
a small tire repair kit is light in wt. and small in size - always good insurance
Old 01-08-2012, 01:19 PM
Dave Colangelo's Avatar
Joe Bob has got it,
Remember if you are going to carry the tools carry the parts as well. Many people always say to carry the fan belt wrench and large socket and then forget to bring an extra fan belt and shims. For parts all you need is a DME relay, fuses, fan belt and shims, maybe spark plugs, oil, and a tiny can of WD-40. Much of these cars are held together by the same 10mm bolt. Weather you get the hex head or the Allan key head style I like to carry an array of these with me. Any auto parts store will have them from .5 inch length to 1.5 inch length, I carry a bunch in a variety of sizes and some washers. They are always good to have and take up literally no space.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 01-08-2012, 01:45 PM
Rescuer of old cars
Arne2's Avatar
If your car has A/C, throw in a 1/2" wrench as well. To change the fan belt, the A/C belt needs to come off first. If you don't have a 1/2" wrench, you'll have to cut the A/C belt to get it out of the way. (Have your dykes handy for that job...)
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-08-2012, 01:56 PM
HarryD's Avatar
You can never have too many tools, just in case:
As found here: Just a Car Guy: 7/1/07 - 7/8/07
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 01-08-2012, 07:29 PM
CIS car........
John,
Just to let you know the car is a CIS. DME relay is for Motronic engines.
Tony
Old 01-08-2012, 07:53 PM
Banned but not out, yet..
RSBob's Avatar
Not for repair - but always carry a couple extra quarts of oil, AAA, and a credit card.
Old 01-08-2012, 07:59 PM
Greek55's Avatar
All these tools suggested are good but don't forget Duck Tape. The best thing is when you don't need it to temporarily keep something together it makes a great cup holder laying on the passenger floor.
Smoke
1982 911SC Rosewood
SCWDP # 0097
Old 01-08-2012, 08:00 PM
