Banned
Minimum toolkit to carry ?
Just realized i dont carry any tools - apart from mix key - in the p-car.
What do you recommend as a minimum set to avoid being stranded too easily ? CIS car. |
RETIRED
Typically what's in the tool kit supplied by the factory, plus whatever you think you might need.
I'm sure others will chip in with comments.... fan belt, with tool for whatever engine you have to keep fan from turning open end wrenchs, 8,10,12,13,15,17,19mm spark plug wrench...the factory one is best, ratchet plugs points if you have them zip ties flat and phillips head screw driver fuses lug wrench flat plug repair or fix a flat (not a fan) allen wrenches tire inflator test light or meter electrical tape dykes crescent wrenches pliers cell phone, prepaid towing card just off the top of my head....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 01-08-2012 at 08:24 AM.. |
John W
Don't forget the spare DME relay.
----------------------------------- John 89 3.2 Targa 123k miles |
how long of a trip.....
normally I carry a cell phone....seems to work OK
Ed M 86' Coupe |
Banned
Apart from the inflator, the cellphone is the only thing i bring...
Thanks guys |
78 in a '71
On glide path...... 1971 911 T Targa 2013 Ford Fusion Titanium AWD 1982 Volvo 245, 1996 Ford F-150 |
RETIRED
Women with comfortable shoes?
I would also add jumper cables....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
5String
What Joe Bob said. I don't carry Allen wrenches or a test light, but I pretty much carry everything else on his list, plus a pair of mechanic's gloves, a flashlight, a fire extinguisher and a couple of mechanic's rags.
Most important components? Cell phone and AAA card, I should think. Re the question mark after "dykes," that's a reference to diagonal cutters, clipper/pliars referred to as dykes. But you knew that, right?
5String Tell not a soul that you have seen me; breathe not a word of what I say.... The Northwest Files |
RETIRED
78 in a '71
5string, That's a new one on me. I've only ever heard them called diagonal cutters. Maybe at one time I heard them called dykes and forgot. There's a lot of that (forgetfulness) going on here for me these days.
AutoBahned
dykes = a type of cutting pliers
throw away the certain-to-maim Bilstein post jack and put in a scissors jack and handle from a 944 put a piece of plywood in the trunk in case you have to jack the car in loose gravel or mud in many parts of the Intermountain West a cell phone is useless; depending on where you drive you may need to carry a few days water, food, and a sleeping bag to survive until another car comes along search on the many other tool threads to find the one that is on "minimum" emergency tools |
RETIRED
I believe that Dykes are a contraction of DIagonal Cutters ....from a wiki article.
They are actually "diagonal side cutting pliers", basically wire cutters. "Diagonal" is shortened to "diags" which then gets pronounced (or mis-pronounced) as "dykes"
RETIRED
AutoBahned
oh yeh - space savers - I have a full size spare
a small tire repair kit is light in wt. and small in size - always good insurance |
Joe Bob has got it,
Remember if you are going to carry the tools carry the parts as well. Many people always say to carry the fan belt wrench and large socket and then forget to bring an extra fan belt and shims. For parts all you need is a DME relay, fuses, fan belt and shims, maybe spark plugs, oil, and a tiny can of WD-40. Much of these cars are held together by the same 10mm bolt. Weather you get the hex head or the Allan key head style I like to carry an array of these with me. Any auto parts store will have them from .5 inch length to 1.5 inch length, I carry a bunch in a variety of sizes and some washers. They are always good to have and take up literally no space. Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
Rescuer of old cars
If your car has A/C, throw in a 1/2" wrench as well. To change the fan belt, the A/C belt needs to come off first. If you don't have a 1/2" wrench, you'll have to cut the A/C belt to get it out of the way. (Have your dykes handy for that job...)
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
CIS car........
Banned but not out, yet..
Not for repair - but always carry a couple extra quarts of oil, AAA, and a credit card.
An air cooled refrigerator. ‘Mein Teil’ |
All these tools suggested are good but don't forget Duck Tape. The best thing is when you don't need it to temporarily keep something together it makes a great cup holder laying on the passenger floor.
Smoke 1982 911SC Rosewood SCWDP # 0097 |
