Chain fence eating turbo
Alternator not charging on Carrera 3.2 but no idiot light either...
I blasted and painted my fan and housing a few months ago. After the paint job, I didn't realize my alternator wasn't charging until recently. I haven't driven the car much at all because I was trying to fix my leaning out issue.........a whole 'nuther thread about a "cliff" and a "Carrera".
![]() Anyways, here's is what is going on (battery at 12.80v's): 1. Key on, no idiot light for the alternator illuminating when engine off 2. Pulled idiot light socket and found a bunch of corrosion on the spring contact - cleaned but still will not light with key on, not running 3. Took scotch-brite to bulb contact and still no light when key on, not running 4. Hooked a 9-volt up to idiot light bulb and it works fine 5. Checked voltage at idiot light socket and found NEGATIVE voltage with (+) from multimeter on the spring contact and the (-) on the sleeve (I'm assuming this is standard for all light sockets?). I assume I have a wire crossed on the alternator???
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel Last edited by Tippy; 03-07-2012 at 04:58 AM.. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
alternator connection.
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
light
here's the circuit.
RETIRED
As above....your connection is suspect.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I saw the test in my manual regarding the blue wire to ground should illuminate the lamp. Depending on if it lights or not indicates what the issue may be.
The ring terminals seem to be mistake proof but maybe not? I can't remember if the blue is the tiny wire or the medium sized one. I'll look today after work. Thanks.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
at the alternator, jump the blue wire to ground and if the dash light comes on, the circuit is fine. it's usually because one of the brushes is no longer contacting the commutator.
Isn't the wires mistake proof?
There are 3 sizes and all of them felt like they engaged the post just right. Gonna try the blue wire test and see if I am getting HOT to both sides of the idiot light socket too. I doubt but I'll double check.
you get 12v to one side of the bulb and the other side (the blue wire) initially is a ground wire through the alternator. once the alt gets charging, that ground wire gets hot and then you have 12V on both sides of the bulb which puts out the bulb.
So,
1. Idiot light DOES NOT illuminate with key on, engine off 2. Ground the blue wire, the light DOES illuminate Dead VR?
Rescuer of old cars
Yes, that was exactly the case in my '84. New VR fixed it.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
What I'm thinking. Thanks
++ on new VR.
Pretty idiotic (pun intended) to have an alternator failure mode that does not illuminate the idiot light ...
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
Ha
the problem is that the brushes on the regulator dig deep grooves in the alternator's commutator, so the brushes on the new regulator tend to be short lived because of the rough surface. the comm is thin and likely can't be remachined, so the best bet is to get a complete unit, new or rebuilt.
Thanks John!
Alternators are pricey - no harm checking the condition of the commutator. (is it called that, even though it's not segmented like in a motor?). Mine was not grooved much at 150K miles - I cleaned it up a bit with thin strips of cloth-backed 220 sandpaper, and I've got 23K on the new VR without issues (knock, knock, knock on wood). I do carry a spare VR though ...
Gonna tear it apart sometime this weekend and take a looksey. Hopefully I am just a VR away from charging.
Oh wait, I have wire up the entire MegaSquirt system before retesting......
If you decide to polish the rotor slip rings/commutator then use sandpaper per earlier post. I recently went through an alt rebuild and was told by an old school alternator shop that using emery cloth will imbed emery and iron bits in the copper and trash the rings in short order.
Hmmm, would have thought the opposite. Thanks.
