MBruns for President
JeremyD's Avatar
Clutch arm, helper spring, adjustment WTF
SO noticed the other day that my clutch was slipping a little the other day.
Low miles on the clutch -
So jacked up the car and checked out the adjustment - and I think I can reason how this works - but in practice - it does not seem to be working correctly
Clutch clevis pin, adjusted all the way in.
Helper spring brings the clutch arm forward
even if no tension is on the clutch cable - the helper spring tries to compress the clutch
If I hold the helper spring out - I can adjust - what I consider normally - but as soon as I remove my finger from behind the helper spring = it rotates and starts applying pressure to the clutch arm
Here's the adjustment on the clutch arm stop - as you can see - no 1.2mm
Really - WTH? the single arm that I had on my 1974 was so much more simple. what am I doing wrong?
Old 01-17-2012, 08:25 PM
What's wrong is your omega spring is in the wrong orientation, me thinks. Do a search and you will find a picture of how it is supposed to fit. That looks wrong.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-17-2012, 08:27 PM
check this thread out. There is a picture of how it is supposed to sit
Clutch Adjustment and Pedal Question
Old 01-17-2012, 08:33 PM
JeremyD's Avatar
Right position
ALthough my spring is a little further "inboard"
Old 01-17-2012, 08:49 PM
Omega spring orientation.........
Originally Posted by JeremyD View Post
Right position
Jeremy,
The orientation of the omega spring in your picture (top) is at 'relax' position (no tension). After you hooked up the clutch cable to the clutch release lever, the helper spring (omega) is pushed rearward to get the helper spring apply pressure to the lever. The lower picture shows the correct orientation or position of the omega helper in normal operating condition. Compare yours to the other transmission set-up and you'll notice the difference between the two settings.
Like you mentioned, the omega spring is a little inboard in your case. It got to come out. You need to push the clutch release lever rearward and adjust the clearance with the clutch positioning lever (small arm with spring).
Tony
Old 01-17-2012, 09:36 PM
E Sully's Avatar
Tony is giving good advice. First remove the cable completly, move the large lever back all the way, the omega spring should push it back near the oil line, and adjust the gap at the screw to 1.2mm. Re connect the cable and adjust to 1mm. Then measure the travel when you step on the clutch pedal. It should move 25mm. If not adjust the travel using the metal plate by the clutch pedal on the drivers floor board.
The Omega spring does 2 things, when fully back it pulls on the clutch cable, and as it moves forward it reverses its action and begins to push on the clutch to assist your foot pressure in releasing the clutch. In it's current position it is in the pushing position, assisting in releasing the clutch, causing your slippage. If it has been this way for a while it could have caused wear on your clutch plate.
It is a little more work to set up then the older style, but when done properly it works better than the old style.
Ed
1973.5 T
Old 01-18-2012, 03:38 PM
schumicat's Avatar
there are instructions you can find in a search on how to get the omega spring in the correct orientation. basically involves gently prying and it snaps into place in the blink of an eye.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 01-18-2012, 04:48 PM
JeremyD's Avatar
Thanks - the clutch arm is hitting the "stop" at the end of the travel - but the other pictures sure make it look like the arm is more extended
Old 01-18-2012, 05:01 PM
E Sully's Avatar
I would try removing both arms and making sure the large arm pivots on the shaft. When I first got my transmission the long arm was stuck to the shaft. I had to pry it off, then clean and grease it.
Ed
1973.5 T
Old 01-19-2012, 02:36 PM
JeremyD's Avatar
I think I got it - it was a spline adjusted too far in - So the clutch did not have enough travel.
I backed everything off - greased it up - lengthened the cable and the cable adjustment - and put it back together. Actually have my clutch cable return to the proper height now.
Old 01-19-2012, 03:00 PM
