Need opinion, what is this twin plugs engine?
Hi all,
I also posted this on 911s registry. Can you please give your opinion on this engine? We found it from the old Porsche garage in Bangkok. At the first glance, the engine number 6631274 doesn't look original to me. The 6631274 is the engine from 2.7RS which I don't think this engine is. It has the Merelli distributor and the Bosch fuel pump that missing all the plate numbers. It has a set of 2.2S velocity stacks. I believe some one might have installed it later on. The engine is now disassembled, I will try to post many pictures that show part number. We really appreciate your help. Burint ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
The Unbreakable RS/RSR door pull http://thaiporsche.shutterfly.com/776 86, 930. 70, 3.2. 67, 911. |
Some more pictures.
RETIRED
![]() If that reads 911/92, it's a 2.7 block from a74 'S'.... edit, 911/93 typo.... Doesn't look like an 83.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 01-12-2012 at 04:36 AM.. |
Looks like 911/93 to me.
72 911 Although it is done at the moment, it will never be finished. |
Banned
911/83 is 73 rs case
is this going to be for sale, I am interested, in it in peices thanks! |
The mahle 95P30 piston looks to be : 3.0L RSR 10.5:1 compression. Sweet!
Deck height dilemma WTB one Mahle 95mm Racing Piston (can anyone ID for me)
- '72 911T - '81 911SC Euro |
arrivederci,
They are 95P30 piston. I think I have not posted this picture yet. Does the 3.0RSR built with 74 2.7S case?
Banned
factory RSR number are
911/74 3.0 rsr 911/75 3.0 rsr 911/77 3.0 rs 911/83 2.7rs 911/93 2.7S USA I think it is common it build a RSR engine from t he 7R case Last edited by dporsche74; 01-12-2012 at 06:39 AM.. |
The one real '74 3.0 RSR I had a chance to inspect had an aluminum crankcase, not a 7R magnesium.
I would rather be driving
Looks like you have a hybrid.
Engine serial number and case type indicate a 76 911S 7R magnesium was the start. The heads are 2.4/2.7 heads. Port size you did not mention but I suspect they have been machined. The 2.2 mag stack MFI is there. What is the piston/cylinder diameter. Given the flat edge on the piston they look like a 92mm or 95mm. It is hard to tell without scale. the twin plug Marrelli is period for the early motor but most of the 73+ twin plug motors I have seen have a Bosch setup. The flywheel is milled down like an RSR but that is not too difficult to replicate on stock flywheel. I think you could have a great engine assuming it all cleans up (lots of corrosion) and measures out in spec. Have fun.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Well the MFI pump is a real RSR pump from a 2.8 or 3.0. Great find. No tags on the pump, bummer. Let me know if you are going to sell the pump!
Mark Jung Bend, OR MFI Werks.com |
Max Sluiter
What is the fiberglass panel on the MFI pump for?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
I have the same question about the fiberglass piece on the pump.
I try searching for pictures of other pump, none of them have it. Many thanks for all answers, I love the word 'Hybrid" from jpnovak, so it is the hybrid RSR. btw. the piston size is 95mm.
AutoBahned
one critical thing about the MFI pump will be the space cam -- might be other differences, and there are some real MFI experts here who can tell about them
did you find that motor in Thailand? |
You've also got the factory lash cap rockers if im seeing them in the picture correctly along with centerlube cams.
If your going to part this, I'd like to get the rockers. tadd
1967 912 with centerlocks… 10 years and still in pieces! |
Max, fiberglass cover was on some of the 906 E MFI pumps and 917 MFI pumps also the 16 cylinder MFI pump. I believe it was to cover the cam follower guide screws in the racing pumps. Photos below might help.
Max Sluiter
Ah, cool. They saved weight everywhere.
This will get very interesting...
David 1972 911T/S MFI Survivor |
Nice
Looks like the early 27mm neck Marelli, the variety used on 906, 911R etc., not the later 30mm neck Marelli with integral adjustment bracket.
I see forged steel RSR rockers and center lube four journal cams - prob RSR. Please post a pic of the front side of one of the cam box covers. Are they dark sand cast magnesium? Looks like a really neat engine. Hugh, is that RHD lightweight 9113601305 delivered to Hong Kong accounted for and still in Asia? Burint, note that your very interesting bosch mfi pump is worth big money. Remember, it is maybe $20k retail to purchase a good RSR pump from Freisinger etc. Also, looks like a gennie RSR flywheel. Some one went to a great deal of trouble and expense to source all those nice factory race bits on your great RS numbered 7R cased hybrid engine find! Here are are pump and space cam numbers to help out: 906E PES6KL60A120 907 901/21 PES6KL70A120RV1612 EP/RLA 1-V837 771 2.2L PES8KL60A120LV1622 EP/RLA 1-V891 908 PED8KL60A120RV1455 EP/RLA 1 V961 917 4.9L NA PED12KL60A120LV1677 EP/RLA 1-V997 2.8RSR PED6KL60?120RV???? EP/RLA 1-V???? SPCAM=V94 3.0RSR PED6KL60A120RV1668 EP/RLA 1-V1077 SPCAM=V109 935 PED 6KL SPCAM=V114
flunder Last edited by Flunder; 01-13-2012 at 07:41 AM.. |
Its a h.ll of a find.
that's what it is . good on ya. |
