El_Mecanico's Avatar
UPGRADE MY 86 3.2 to 10.5 COMPRESSION
Since I have already torn apart my engine for a thorough inspections I would like to upgrade it. Has anyone upgraded to EURO specs? What needs to be done to install JE 10.5 compression? I assume this would add about 20 HP. Any thoughts in benefits? Would I need to dual plugs. In my area 93 octane is available. Please your thoughts and If you found it to be beneficial?
Andy
1986 Porsche Carrera
1997 Porsche Boxster (Sold) :0
1995 911 Cabriolet (Sold)
1971 Porsche Targa 911E (Sold)
Old 01-13-2012, 03:25 AM
drola's Avatar
I've often wondered the same thing. someone out there must have done this
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
2014 Ram 2500 Cummins
Old 01-13-2012, 05:39 AM
Chain fence eating turbo
Search engine rebuild section
Old 01-13-2012, 06:18 AM
LakeCleElum's Avatar
My Max Moritz pistons (3.2) are 9.7. I use good fuel and total advance of 29 degrees. I'm fine, but make sure I don't drive in in such a way to cause it to detonate.
With 10.5, twin plugs might be a good idea.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 01-13-2012, 06:38 AM
IROC's Avatar
I have 10.3:1 Mahle pistons in an '88 3.2 with single plugs. 93 octane is right on the ragged edge. I've had a tank of bad gas result in detonation and I use race gas at the track...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 01-13-2012, 08:04 AM
lonewolf's Avatar
Mahle pistons only for me .
Never use JE. seen too many problems.
A lot of factory hipo engines from the 426Hemi to the 911 euro 3.2 use 10.23 to 1 comp ratio.
I think the factory euro 3.2 is the best choice for a strong hp and relliable motor.
Old 01-13-2012, 09:25 AM
I was tginking go euro spec but what exactly do I need to do
Old 01-13-2012, 02:27 PM
Formerly known as Syzygy
Canada Kev's Avatar
My '87 RoW obviously has the Euro pistons/cylinders and single plugs. I don't have any issues with detonation on the 91 octane that we can get here. Mind you, our summer temperatures are usually lower than what you'll experience there. My elevation is about 2200 ASL, so that'll make a difference as well. Whenever I get out to the BC coast, I make sure I fill with 94.
Kevin
Old 01-14-2012, 09:44 AM
Wise man!!
Its a bit of a balancing act running high (over 9.5:1) compression, reasonable ignition timing, and dealing with hot weather using less than optimal fuels to avoid broken rings and pistons.
The rule is "Less is More",..
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-14-2012, 11:05 AM
I guess I will than re-use my Mahle pistons and cylinders...they are in great shape. WOW these engines are so darn expensive. I split the case and completed a thorough cleaning and my curiosity decided to check out the oil squirter's in the process I was able to manage to jam 3 of them. I will need to find a local Porsche mechanic. Anyone know of a reputable Porsche Machine shop in Mobile AL or Pensacola FL?
Old 01-14-2012, 05:15 PM
