vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Transmission Wire Just Above Axle - Help?
I am dropping my motor and there is a thin wire connected to the transmission just above the axle on the passenger side of the transmission. It appears to have a strange connection. I have to assume I need to disconnect before I drop the motor and tranny. Any ideas on what it is and how to disconnect?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 01-16-2012, 06:14 PM
on your 83sc, that is the magnetic pick up for the speed sensor. It just sits against the case kept on by a small clip. Use a 10mm socket to undo the clip and hang it off to the side.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-16-2012, 06:19 PM
Speedometer cable..........
Vance,
There is an electrical connector inside the tunnel located close to the transmission shift coupler. Trace the wires and you'll locate the connector sitting inside the tunnel. Label them if you like but it does matter which one go to either connector. They are reversible connections. HTH.
Tony
Old 01-16-2012, 06:23 PM
Peter Zimmermann's Avatar
For fear of damage to the speedo impulse pick up, we just undid the quick disconnect inside the tunnel, near the coupler (under the coupler tunnel). Gotta go in there to disconnect the shift linkage anyway, so...
Keep the Shiny Side UP!
Pete Z.
Old 01-17-2012, 11:21 AM
