?????worn shifter coupling bushings
![]() Thanks everyone Kevin
KEVIN WOOD 70 911E TARGA |
Administrator
Replacing the worn bushings is a very cost-effective way to create the impression that you have a whole new transaxle in the car. I recently had mine replaced,
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Woody,
That sounds like the 'normal' factory bushing, particularly if there is no vertical 'play' in the smaller dimension of the slot in the bushing. the one thing you should be looking for is cracks in the plastic ... when they develop, the bushing tends to crumble into little pieces that are found later on the floor of the tunnel.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks guys. They are plastic bushings with only lateral clearance. If I made some bushings out of brass would that tighten it up. Or should I leave it alone. The bushings look to be in good condition.
Thanks Kevin ![]()
i found the same type of "original" bushing in my '73 911E. i went ahead
Kevin, no need to make your own. You can buy replacement bushings cheap from Pelican. They are some type of polyurethane
Yes definitely do this, it makes a profound difference in the shifter feel. ![]()
Chuck Moreland - elephantracing.com - vonnen.com |
Warren Hall Student
Yes change the bushings
Bobby |
Irrationally exuberant
I've done 2-3 of these bushings. To remove the pin, put the splined part in vice with aluminum jaw inserts
The Weltmeister bushing I've used were all too tight side to side. I removed material from the back side (not the surface that rubs) to make them fit. -Chris |
I did mine recently
It feels much better going into gear...to the point that I am considering making a shift gate for the shifter....like Ferrari's have. Bob
Bob Hutson |
Woody,
I made mine out of brass on my lathe. I didn't feel like waiting a week or two to buy something I could make in 10 minutes for free! Oh yes it is tight now. I made my bushings a light press fit (maybe .001") in the coupler body. This holds them in with no need for anything else. Dennis H. 72 911E |
Hey Guys,
This is a great thread. I just had my synchros replaced (again) I went to the Pelican page for the bushings, 1) Shift coupler bushings (pair) 2) Front shift coupler boot 3) Rear shift coupler boot or The complete shift coupler - which sounds like a good deal since I won't have to mess with the pin removal. I'll gladly pay the $77 to save myself alot of grief Any words of advise or gentle prodding in the right direction?
'95 993 C4 Cabriolet Bunch of motorcycles |
Like Richard, I too am a little unclear as to what I should be replacing. There are many items listed in the shift linkage section of Pelican Parts "Parts". My car is difficult to get into 2nd, so I was thinking of changing out bushings, adjusting clutch, etc. before opening up the tranny.
David 1967 S |
in the shift mechanism, replace:
the ball at the bottom of the shift lever the mating cup that the ball fits into the bushing that holds the shift rod in place as it traverses the shift tunnel. under the plate on the floorboard between the back seats, replace: the shift coupler bushings. all told, the bushings are approx. $40. in both cases, you'll need to remove a threaded pin that helps attach also, on the shift rod, mark in indelible ink the location of your shift coupler relative to its alignment on the rod. this will help you get it reassembled relatively closely to where it was prior to taking it off. if your car is shifting poorly, adjust the shift coupler per the factory workshop manual. this will take a few attempts. each adjustment will require a quick trip around the block to see if you "nick" any gears while shifting. this solves "alignment & bushing" related shifting problems, but in no way does it solve major transmission problems. |
For a complete "rebuild") I'd recommend replacing the plastic ball cup bushing (the one under the shifter up front); the guide bushing on the horizontal section of the shift rod (just to the rear of the shifter), the bushings in the shift coupler or the entire shift coupler
Thanks alot guys. I will probably just make some bushings because our dollar sucks
Regards Kevin ![]()
73 on 914s had a similar coupler outside of the firewall. the bushings in it have no lateral play. the bushings can be used in a 911 coupler
