My 1987 porsche 911 is a delight to drive and care for but I can not find the source of an annoying whistle when the engine idles…it disappears when you drive.
Any suggestions? |
It sounds like the aux air valve might not be closing all the way and leaving a small gap when its closed. Or supposed to be closed. Like blowing a blade of grass between you palms.
The shut off lever is able to vibrate alittle. Try pinching off the hose and see if it goes away.
Valkyrie |
The 3.2 doesn't use a Aux air valve. There is an item called the additional air valve near the oil fill neck that will rattle when cold.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
The intake runners can whistle when leaking, although I'm not sure why it would only occur when at idle. Checking to make sure all the nuts are snug would be a good first step.
Chris '87 Targa |
Is your car new to you? If so, a 911s cooling fan can make a whine / whistle noise at idle. If you really want to know, remove the fan belt and start the motor and see if it doesn't go away. Don't run it long though without the fan moving air.
Tell it like it is or don't tell it at all. |
Sorry did not look at the year.Ignore
Valkyrie |
Are you still using the standard air filter?
My '86 has a cone air filter behind a hotwire afm and I can hear a whistle at idle. It's my understanding that what I am hearing is the air squeezing by the closed throttle plate -- when the throttle opens, the whistle goes away. I suspect that the standard airbox hides this whistle. |
The o-ring on the idle speed adjustment can dry out. Easy to test, just press on it while running and u'll know.
Thanks guys for the responses, will follow up...
Funny this should be mentioned,..as I attempted adjustment of base idle and the damned thing hissed at me,...very briefly,..(and not easily repeatable)...I left it alone (cal'd) ,..but suspected something "in" there was amiss...maybe the very part you mention? Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
+1 on Chris' sugestion about the intake runners. Make sure they are snugged down. If that's it, the whistling will stop as soon as you snug the offending one down.
Marv Evans '69 911E |
Member 911 Anonymous
+1 on Idle Adjustment screw O-ring.
To test, at idle lift the lid and wiggle the screw, if loose it will whistle.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
RETIRED
Does it have an air pump for smog?
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
You can take a hose about three feet long and put it to your ear and probe around for the location of the noise.
Valkyrie |
so, per the above, looks like my idle adujstment screw o ring is leaking/whistling. I see the idle adjustment screw on pelican (Pelican Parts - Product Information: 930-110-919-00-OEM) but no o-ring. What to get?
Thx, darrin |
I'm gonna' check the factory manual on this,..I think I've the same issue on my '89....at least that o-ring is worn..
Doyle
thanks! -- on mine, turning the adjustment screw less than 1/4 turn has (temporarily?) silenced the whistle
