76 911S Targa
Have you put the car on a lift so that the right front wheel is hanging free and then try to move it to reproduce the sound? Violently moving the wheel up and down to simulate a bump may help you localize the noise. Also there is that plate that covers the steering rack and brake master cylinder. Is that bolted on tight?
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
My car had a thump when i bought it and tightening the gland nut fixed it.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Yes, the bash-plate is bolted down securely. I removed/replaced it when I swapped out the tie-rods. |
+1 on wheel bearings that someone mentioned near the top
If the car was rolled around without the transmission the wheel bearings will need to be replaced. Cost me roughly 300 bucks. Problem solved
Nick '78 Turbo Look w/ euro 3.2 |
I would rather be driving
Does it have Bilstein struts? IN addition to the top gland nut (my first thought) there is a strut tube locating bushing inside Bilstein struts that can wear out.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
right, green=bilsteins.
1987 911 Carrera Cabriolet (sold) 2009 Prius (daily driver--keeps me sane) 2011 Mercedes GLK350 (wife's car) 2002 Volkswagen Beetle Turbo S (son's car--keeps wife sane) |
In a different car, it made the same noise when the bushings in the strut top were wore out.
this happened to me on my '88, and thankfully it was the 2 nuts tightening the front belly pan were loose - after a bit of driving...i know it sounds too simple, but we cannot be above everything...worth a try, anyway...
Trying to get to the "gland nut" now... |
Take the cat out of the dryer.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
WUNDERWAFFE
Have you checked for worn down or damaged strut spindle.
Charlie 1986 Carrera |
Fixed it! As some recommended here...check the simple things first. I couldn't lower the strut out of the top mount as my car is slammed. When I put the strut top nut back where it was, I noticed, compared to the driver's side, there was much less thread sticking out (1/2" vs. 3/4").
I cranked down on the nut until it matched the other side, then took it for a spin. No more "ka-thunk"! Nut was loose this entire time...
WUNDERWAFFE
Sweet, and congrats bro
