Danny_Ocean's Avatar
Ka-thunk...ka-thunk, ka-thunk...ka-thunk. What is this noise?!?
I have a noise (ka-thunk) coming from the front passenger wheel area...typically only happens when coasting or deceleration and upon hitting a bump in the road.
I thought at first it was worn sway-bar bushings. Those have been replaced and the "ka-thunk" continues. Then I thought it was the horizontal cross-brace between the shock towers. I inserted some plastic washers between the mounts and the heim joints...nope.
The only thing left I can imagine is the strut. It's either worn out or bottoming out (rubber stop missing?). How to check for a worn strut? The car handles fine and doesn't nose-dive upon hard braking.
Anything else in that area that "ka-thunks"
Old 01-19-2012, 08:24 PM
LakeCleElum's Avatar
What year? I had this in my 73.5....Front sway bar was sliding back and forth....Was hitting he dust cover of the strut....PO had put in new bushings and had not pushing the linkage into the fender, allowing the bar to "float" back and forth....YMMV
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 01-19-2012, 09:52 PM
tobluforu's Avatar
Check the gland nut on the strut.
Old 01-20-2012, 03:56 AM
stormmaster's Avatar
Send a message via AIM to stormmaster Send a message via Yahoo to stormmaster
oh no.....not the dreaded ka-thunk ka-thunk ka-thunk noise......nothing worse than that....
except maybe the thhp...thhhp....thhhp....hssss noise
Don Booth
87 Carrera Coupe (Current)
70 911 T Coupe
74 914
Old 01-20-2012, 04:55 AM
Check to see if your wheel bearings are tight. You'd be surprised how they can loosen over time and then kathunk over bumps.
Old 01-20-2012, 05:14 AM
pete3799's Avatar
This would be my guess.
Pete
79 911SC RoW
Old 01-20-2012, 05:18 AM
Friend of Warren
Agree. Had it happen to me a few thousand miles after replacing the struts. Guess I didn't torque it down enough. If it is loose you can get a pipe wrench in there and tighten it down while in place.
Kurt V
Old 01-20-2012, 06:13 AM
76 911S Targa
This is also the classic noise made by a loose/failing ball joint or tie rod end, particularly the description of hearing it when going over a bump. Check those for sure.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 01-20-2012, 06:39 AM
Shuz
Does the frequency of "ka-thunk - ka-thunk" change with the speed your car travel? Is it proportional say 10 "ka-thunk - ka-thunk" at 10 MPH and 20 "ka-thunk - ka-thunk" at 20 MPH?
What I am getting at is it a wheel rotation noise that repeats or not...
I had a similar issue with my SC due to some crud in the wheel. The noise went away after pulling the wheel and blowing some compressed air between the pads and calipers.
RBL>
Old 01-20-2012, 07:26 AM
That's the sound of loose lug nuts as well. Doubt that's the case, so I'd guess loose calipers or bearings.
Old 01-20-2012, 10:08 AM
'79 SC. I installed the sway-bar and bushings myself. It is installed correctly. Ka'thunk was there before and after I replaced the bushings.
Old 01-20-2012, 03:12 PM
Gland nut is which nut? Does the strut need to be removed to reach it?
I gave the wheel the "wobble" test when it was on the lift. No play up/down or front/back.
Old 01-20-2012, 03:13 PM
I just installed new turbo tie-rods. Sound was there with the old tie-rods too. Balls joints appear fine.
Old 01-20-2012, 03:14 PM
RBL>
No, the "ka-thunk" is the same, regardless of speed. It's only change in frequency of ka-thunks is how many bumps I'm running over at the time.
Old 01-20-2012, 03:16 PM
I just re-built the wheels and mounted new tires. Lugs are torqued to spec.
Loose caliper? I'll check that.
Old 01-20-2012, 03:17 PM
tazzieman's Avatar
I have the same issue which I had thought might be the ball joint...After new BJs , tierods , bushings(sway and A arm) and replacing upper strut mounts, strut pins, rotors, bearings...noise is still there. Next is to disassemble the strut , even though the shocks are very firm.
Let me know what you find , as I won't get around to looking at mine this weekend!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 01-20-2012, 03:46 PM
It's always better to check the wheels/ bearings with the car on the ground. Steering might need to be checked on the lift.
Old 01-20-2012, 03:48 PM
poorshe911's Avatar
how about a bad CV joint?
Old 01-20-2012, 03:53 PM
New CV joints. Sound is definitely coming from R/F.
Old 01-20-2012, 04:19 PM
