HELP: Need TWO nuts (big)!!!
Guys/Gals: I bought a set of late model Carrera axles (87-89) for a conversion. When I went to install them I found my early Carrera axle nut(s) are smaller. Can anyone please verify the size of the axle nut (threads on stub axle) size? I believe I found it is either a 20 x 1.5 or 22 x 1.5 (mm)...
Thanks in advance for your assistance. I can't move the car until I get the hubs locked down!!! Tony/Crackertoo On the hunt for two nuts! |
Aircooled Breakfast
Go for the Porsche axle nut (it's a lock nut) and make sure you have the proper washer.
460nm/340ftlb. use the porsche nut for sure.
JFYI - For anyone else looking for the hub bolts...Advance Auto Parts sell Axle bolts with a nice flange for a Mazda Miata. Honestly, I like it better than what I had as the flange is perfectly sized to the recessed area of the hub (for the washer).
I have some but I would need to go ask my wife if I can get them out of her purse. ![]()
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html 930 Cab - ex-IA car, 3.4L, 1.2 bar, G50 996 Turbo - X50. |
Banned
I think you will need to do some serious soul-searching in order to find what you are seeking!
Thread Tools | |
Rate This Thread | |
