Finally got the SC started!!
Hi guys,
I changed the 3 easy plugs on the left side of the motor and fixed the vacuum leaks, and was rewarded with a motor that runs, but wont idle without throttle input. The motor has not been run in about 18 months. Its was stil running smokey, going from almost no smoke to allot of smoke and the temp never got out of the first box after running for about 8 min, I need to change the plugs on the right cylinders, and tighten the fan belt. Can you tell me what the bottom light that illuminates red on the temp/druck pressure gauge is? Here is a youtube link to the motor running, any suggestions 80 911 sc finally running.mp4 - YouTube thanks adam
1980 Porsche 911 SC 2005 Toyota Altezza Jap spec (IS300) too many boats |
the warning light is battery/alternator. it could just be because of loose fan belt, or mean alternator is not charging properly.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
ok thanks, the belt is loose for sure so will replace it, not knowing its age
if you are going to replace the belt, order the 6 washer you must have for the pulley. You need 6 no more no less. If you have less the nut will bottom out and do very bad things if you have more you wont be able to adjust it the way you need it to.
The idle can be adjusted by the idle set screw on throttle mechanism. These cars take some time to heat up, at least mine does so 8 min is no surprise. it takes me a good 15 or 20 to get to operating temp. The smoke is no surprise, its the valve guides if I had to guess. Once you get the car running with the right oil, considering how few miles your car has you should see it burn less smoke as time goes on. Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
All right some progress made! The plug on the right side seem really hard at first especially the front one. but you will get the moves down in time, Folks do remove the AC compressor to do a valve adjustment, but you should be able to do the plugs with it in place. The fan belt is tightened by moving spacer washers from the middle to the out side of the outer part of the pulley. You may want to replace the belt when you take the pulley apart. Have you changed the fuel?
Also have you read about the need to get the engine really warmed up when driving? These engines don't like to start and just drive a short distance, with all that oil it takes a while to warm up. You may end up doing a couple of laps to do that, Not a bad thing :-) Did you get to drive the car when your Brother had it running? Cheers Richard |
We have not tried to put it in gear yet. Neighbors came home so i decided to call it quits until tomorrow. Will change the other plugs then see what difference it makes. The backfiring had almost disappeared with the occasional maybe every3 or 4 min. I figured it needs to run for a while before i place any judgment on it the smoke.
There is a funny bearing noise, that i think is coming from the fan/alternator, will have to check it out. Just glad to see it run, give me hope going into the clutch change. Gas is mostly new, i put 5 gallons in and it reads 2/3 tank, how big is the tank?
The noise you are referring to may be the fan rubbing against the outside of the housing. I had this issue for some time, put a new belt on and it was gone.
Regards Dave
There is a special tool for holding the fan belt pulley to remove the nut that holds the pulley together. Once you get the belt off you can spin the fan to check out the condition of the bearings in the alt.
It is a large tank, around 20 gals. Cheers Richard |
Correction one of my previous posts. According to the owners manual for my 78SC it is 5 washers for the fan pulley. I have also read 6, I cant remember how many I put in, but if the manual says 5 that should be right.
Regards Dave
Fleabit peanut monkey
Noise from the alternator is a good thing relative to other noises.
21.5 gallon tank size. Deflect is about 1/2 inch when new belt is installed. Follow the other posts. You make a real good observation in "once you get the moves down". When you adjust your valves you will be amazed at how adept you feel at the end of the process vs. the front end of the process. I adjust my valves every few years and when I start, I ask myself because of may fat fingers "Should I be doing this?". Spark plug change out works well for me with two 3/8" socket extensions. One about three-four inches long to clear the engine compartment frame (with rubber filled socket) then another stubby extension about 1 1/2 inches long to allow the socket wrench to fit in the 3/8" drive hole. Still takes almost an hour to change them all with phone calls and self congratulation after each plug install. |
Needs a tune-up.......
Adam,
Good job!!!!!! Next do the tune-up and tighten that loose heater blower motor. And discard that duct hose on top of the engine. Some TLC and you are ready for the canyon drive. You'll know when you car is in top shape when you start and drive out of your parking spot without waiting for it to warm-up. Tony |
Im actually thinking of pulling off the heaterblower as it never goes below 65 here.
Are the pulley washers reusable, or do I need new ones?
Pretty sure you can reuse pulley washers. As far as gas goes, you added five gallons and it shows 2/3 full, so there was already a lot ofgas in the tank. How old is it? I'd run it out, or drain it, and start with fresh, and Techron or something, to clean the injectors. And really warm it up, eight minutes is not nearly enough. Good luck,
Don Ivey '87 Carrera |
I wasnt sure if the fuel injector cleaners we're safe for CIS. Im assuming there is a drain plug under the tank.
Adam
you can reuse the washers if you wish, you will however most likely find that when you pull them off one or more of the washers will be mangled in some kind of way. If they are not the edges may be rusty or worn out or the washer may have been crushed a bit thinner. Fresh washers are cheap and help to maintain the right distances you need for proper belt installation. Its worth the few dollars to make sure the belt pulley is seated correctly. If the washers dont take up enough space the nut will bottom out on the shaft and mangle the threads.
As for the heater blower, I say pull it. Mine does not even work, ill admit I notice it in the northern winters but I put up with it as I almost never drive the car in the cold any way. It is a lot of dead weight if you will never use it. If you think you may need it one day a year, I'm almost positive there is an adapter that uses the main coolant fan to push some air through the system. Regards Dave
Changed the remaining 3 plugs, pulled the heater motor and after checking for refrigerant, decided to pull the a/c compressor. Guess the blower, condenser and related hoses will come out soon.
The motor ran its best almost no smoke and smoothed out allot, just need some time to push it outside and let it run for 20 or 30 min. Almost wants to idle without foot on the throttle. Interesting observation, it wont start with me giving it some gas, only with my foot off the gas will it start and then i give it a lil bump and it starts running. Im hoping with running it a few more times everything will settle down,and idle on its own, and stop smoking. Then I can proceed to drop the motor and do all the other things on the list. Just want it running satisfactory before i take it apart so i have a reference. Adam
When you give it gas you are actually giving it air by mechanically opening the throttle plate. An SC in good running order will start with the throttle open but you should not have to do that. Routine starting is with the key only.
Perhaps you have not identified all of the air leaks and by opening the throttle it creates an even more lean a/f ratio. How does the engine start when stone cold? If you do have unidentified air leaks this should be the time when the engine starts easiest as the WUR is on its most rich setting. As time passes with the key on, battery juice will lean out the WUR even when not running. If you run the engine for several minutes (not sure exactly how long) , the engine may become warm enough for the cold start valve to no longer function. So you then have leaned out control pressure and no start valve function. Couple this with false air and you have running issues. On a separate note - Have you tried adjusting the air bypass adjustment on the drivers side of the throttle body? It is a screw about the size of a dime with a large screwdriver slot. Turning it in cuts off air and out (CCW) adds air. CCW increases RPM and may allow you to let it idle by itself. This probably is not the only issue you have but it may give you a break while you track things down. I have found that when my car is running well (leak free) I can turn the screw CW and kill the motor when it gets near the end of travel. If I have air leaks, I can't kill the motor. Back to leaks - You can search for air leaks with starting fluid and if you really want to nail it, use the boyt911SC method and force air into the intake system and see where it leaks out. It's not really Tony's method but he is very thorough. If you are interested I can find some links. Good job! Edit - Also look at your plug wires in the dark - real dark with no lights around. Let your eyes adjust for several minutes and look for fireworks around the distributor and wires leading to the plugs. Last edited by Bob Kontak; 01-24-2012 at 03:31 PM.. |
Stone cold it takes a few tries to get going, 5 or 6, then it starts with no throttle, give it a little throttle, and backfires a few times, runs really rough, then gets going after about 3 or 4 mins of rough idle .
If i leave the key on for 30 sec it starts with a big sure to 2k then shuts down. It starts only when i go straight from key off to ignition and start. I'm kind of expecting this though since it hasn't been run in while, am i mistaken with this thinking? I know the air box isnt leaking, as i had smoke coming out of the air flow sensor plate, and out of the pop up when i opened it, but not out of the physical air box. I plan on changing all the vacuum lines when the motor gets dropped, and doing the leak test as well. The wires are the original braided bosch wires. i was playing with them and have not been shocked yet.
My 81 has set for 6 months and started in two turns. A little ragged for a few seconds but then ran well.
The vapor observation from the pop off and air flow sensor is not a test. Picture one of your intake runners sucking air past the base gasket. Do you think there will be vapor being forced out of that crack when the airbox is at atmospheric pressure? Not a chance. The air bypass screw adjusts the air into the system in a very small amount but can impact RPM significantly. I am saying constructively - I do not think you are taking the vacuum leak issue seriously. Vacuum and pressure are the fundamentals of CIS Edit - also do the dark test on your plug wires. I agree that not getting bit is a good sign they are not in bad condition but humor me. Last edited by Bob Kontak; 01-24-2012 at 04:15 PM.. |
Can I use the hose from the oil tank to air box be used for the leak test?
