911 Rear Rotor Unknown Object
I have taken apart the rear rotors from my 1977 911S and found these clips? in them. They are located beside the parking brake adjustment holes in both.
Picture 1 is the way they were found and picture 2 is the clip pulled out a little. I have found no information or pictures/part numbers. What are they for and do I need them? ![]()
1977 911S Sporto |
wheel weights to balance the discs.
Bruce |
Thanks Bruce,
Since I need new rotors, will they come with them or do I need to buy seperately? Where would I get them?
1977 911S Sporto |
new rotors should come balanced out of the box
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Thanks guys
Flat Six
+1
You can just make out the rotor balancing cut in the edge of this disc:
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
