I have a 1980 Euro 911SC with a 930/09 engine. The cams are maked with the 930 147.08 (left) and 930 148.08 (right). The Bently manual has the specs for 930/04, 930/07 and 930/16 engines. Anbody have the valve overlap adjustment specs for mine? Thank You.
John |
From "911 Performance Handbook"
Intake: Opens 7 BTDC, Closes 47 ABDC
Exhaust: Opens 49 BBDC, Closes 3 BTDC Emanuel PS: Sorry it took so long...
"Motorcycles... the cigarettes of transportation." Seth Myers |
Emanuel, I was looking for the valve travel 360 degrees from TDC. Is it 1.55mm (0.061")?
1.4 to 1.7, so right between them is the suggested spec.
I don't see that listed. I also checked Porsche 911 Story and don't see it there either. Sorry.
Emanuel
Thanks, for the replies! I wanted to check the cam timing before I tear down the motor on Saturday. Thanks again!
John |
I accidently pasted this reply here, please disregard.
See if this link helps. camshaft timing specs for a 930/09 engine
John Adams 1980 ROW 911SC Last edited by Jadams1; 02-03-2004 at 06:03 AM.. |
