Mech Brake switch-Led's- No Relay
I wired a mechanical brake switch off the mc brake switch and did use a relay,because I replaced the std brake light bulbs with LED's
Question is, am I OK without a relay since the led brake lights draw very few amps?
Without a doubt, the mechanical brake light switch sure gives me peace of mind that the brake lights go on immediately when I touch the brake pedal .
The LED's just add to the safety margin, IMO.
1979 SC
1986 Carrera 3.6 L+
Old 06-16-2016, 07:10 PM
Wer bremst verliert
JohnJL's Avatar
I think you want as little complexity/opportunities for failure as possible on a brake circuit and relays are prone to eventual failure.
Add up your lights and their draw, do they exceed your switch's specified max?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 06-16-2016, 07:27 PM
Banned but not out, yet..
RSBob's Avatar
If you use cruise control you may find it no longer works because the unit expects a certain amount of resistance from the standard bulbs.
Old 06-16-2016, 09:43 PM
Thanks Bob,John,i don't have cruise, but the emergency brake light is now on all the time,since Tapped into the leads from the mc brake switch.
How do I correct this ?
1979 SC
1986 Carrera 3.6 L+
Old 06-17-2016, 05:14 AM
tharbert's Avatar
Not sure this applies but...
"Reset Brake Warning Light
After brake repairs are completed, the brake warning light on the dashboard may be on. It can be reset by briefly disconnecting the battery ground strap."
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 06-17-2016, 06:32 AM
