High Rev's/Unwanted acceleration
Hi all..
New to the Forum but I've been monitoring for several years now with many great lessons learned here.
I have a 1985 911 Carrera---in the past year I've put a new Clutch, new Transmission, engine sensors, on and on and on and I still love my car!
Last night I was driving and as I took my foot off the accelerator the pedal actually went towards the floor and the car sped up. When I instictively took it out of gear the engine reved very high than settled back to idle? Ok so I was shocked and it only happended once but any ideas here? I was not using the cruise control (never do) but it almost felt like it may have had something to do with it??? IDK??
Any thoughts, ideas, where to start?
Old 02-07-2012, 11:14 AM
porwolf's Avatar
Off the top of my head I am thinking: Throttle return spring broken. But I don't know where that would be located, in the engine bay? I would have to look it up.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-07-2012, 11:29 AM
I would check the throttle linkage under the car. These have a habit of sticking now and then. Might clean and lube it and see if that remedies the problem.
2007 Cayman
1986 Carrera coupe (sold)
1979 911 SC targa (sold)
Old 02-07-2012, 11:36 AM
muck-raker
kidrock's Avatar
+1, you will need to clean and lube the portion of the throttle linkage that attaches to your transmission housing on the driver's side. Piece of cake.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-07-2012, 11:47 AM
make sure that none of your cruise control cables have become dislodged. I had a scary incident similar to yours and I just kept accelerating. What happened is the bracket that holds the cruise control cable fractured and let the cable become dislodged which actually caused my issue. I was able to mcguyver it with a piece of wire that I found on the ground next to my car when it happened. Look above your air cleaner and to the right of your blower motor. This may be your problem. I eventually epoxied it in place and have not had a problem since. Good luck as this scared the $%^& out of me when it happened on a busy freeway.
Old 02-07-2012, 12:00 PM
+1 on checking cruise control...
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 02-07-2012, 05:24 PM
a couple of zip ties keeps the cruise cable plastic block in the bracket. also see if the cable sheath comes out of the plastic block. either one can hang the throttle.
206 637 4071
Old 02-07-2012, 08:02 PM
Dave Colangelo's Avatar
I dumped my cruise unit long ago, it was a nice weight saver for some thing I never used. IF you don't use it I would advise considering the same. The motor is a solid chunk and weighs quite a bit.
Regards
Dave
'78 911SC Targa (Back In Action!)
'00 996 Carrera (New kid on the block)
'87 944 (college DD - SOLD)
'88 924s (high school DD - Gone to a better home)
Old 02-07-2012, 09:18 PM
Eschews Obfuscation
dhagood's Avatar
+1 cruise control. it's really easy to bump the cruise control lever without intent.
'84 Porsche 911 Targa
'97 Ford F250 Heavy Duty
'98 Volvo S70
'02 Subaru Forester
'05 VW Passat TDI
Old 02-07-2012, 09:48 PM
The apparent speed up issue would seem to point me in the direction of the carpet pad binding/pushing on the gas!
Old 02-08-2012, 05:30 AM
Thanks everyone!!!! As it appears we will be getting snow here in the Northeast today and maybe Sat. the car will be in the garage until the salt is gone!!! I'll have the opportunity to check out all your suggestions this w/e. Thanks again!!!!!!!!!
Old 02-08-2012, 09:28 AM
Always learning
I don't think it would be the spring as it accelerated. There may possibly be interference in the tunnel. Of maybe at the pedal cluster. Ie when pushing in the clutch or brake pedal the shaft rotates and turns the throttle bell.
Something like a paddle pop stick , rubbish etc
Old 02-08-2012, 07:05 PM
