1973 RSR rear wheel hub
Anyone have an origional RSR wheel hub, or pictures, or knowledge about them? Its a 5 bolt hub.
Mike |
i have a few sitting on the shelf; they are constructed of aluminum alloy
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Dave & Bill
Do you have any pictures, both front and rear of the RSR wheel hub, not the aluminum top hat? The street hub, which must be very similar to the RSR piece, will not fit inside the RSR top hat. It may fit inside aftermarket hats but not a RSR top hat. It appears that the factory reduced the diameter of the street hub so it fits inside the top hat. However when you do this you must cut the hub down almost to the edge of the wheel bolt heads. I wanted to see an origional to see what the factory did in case I was missing something. Mike Last edited by Gunzel; 02-11-2012 at 08:46 PM.. |
Sorry, I don't have any pics of the actual hub
