Agfours
915 Tranny issue diagnosis needed...(updated with diagnosis)
Been searching the forum but haven't found an answer in direct response to a couple questions -
Recently, when cold at first startup, I'm having trouble engaging ANY gear. I used to be able to 'pre-engage' any gear without issue (push the lever 1/2 way in to a gear until I get the firm spongey pillow resistance). Now, I get a hard wall of resistance before ANY gear unless I keep rowing through and/or blip the throttle in neutral. It doesn't grind in 1-5, just hard wall of no-go resistance plus grind in reverse. I don't get this problem while driving. Doesn't seem to happen as often if the car is warm. Additional data points (may or may not be related, but for full symptom analysis ![]() 1. At a stop light, from neutral, I used to be able to consistently touch 2nd before 1st and it would slide like butter right in to 1st given 8 out of 10 times. Now, touching 2nd doesn't work that often, but touching 3rd does work better. This used to be the opposite. 2. When I use 5th gear, and disengage it (at speed) to prepare for a downshift, it seems to really eject the gear lever with a riddance. No grinding, just stiff against the spring when engaging. 3. When downshifting to 4th or 3rd at speed, I need to hold the lever in 'pre-engage' position for a second or two before engaging gear to prevent either refused shift and/or a grind. No problems on upshifts. About 2000 miles ago, I replaced the clutch cable, changed to Kendall gear lube, installed all new shift bushings, Seine kit, and Wevo Shift coupler. I have new engine / trans mounts in hand, but not installed yet. Prior to my ownership the trans got a new 1st and 2nd gear shaft (the $2300 part) plus other rebuild parts, new clutch, TOB, etc. about 10k miiles ago (I have the itemized rebuild receipt from PO). About 69k miles on car. Has the new clutch cable stretched or is this symptomatic of something else? Help!!
Paul Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..." Last edited by agfours; 02-16-2012 at 10:59 AM.. |
Hard to tell exactly but I would start with the clutch cable. Adjust to specs and see if the condition improves.
Also, check the condition of your transmission and motor mounts. If old and worn out they could be allowing movement under torque, causing misalignment of the linkage and bits. EDIT- check the shift coupler adjustment as well. Even if it's slightly out of whack it can create problems.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Kind of sounds like a clutch issue.
With car parked on street with some room, engine off, put car in gear. Depress clutch. Start engine. See if the car moves or wants to move. You can do this kind of thing in your garage, but have to be careful. That may be too easy, but it seems like you may not be getting full disengagement. I suppose your coupler could be a hair off in its rotation adjustment |
Agfours
Paul Present and accounted for: 1986 Carrera Coupe, 2021 Audi SQ8...Gone but not forgotten: 1987 Carrera Coupe, 1996 911 Carrera C4S, 1985 911 Carrera Cabriolet M491, 2011 Cayenne Turbo, 2001 Boxster S....Me: "What is your return policy?" FLAPS rep: "We really expect you to keep it..." |
So the clutch engagement point - where in its travel the pedal is when the clutch starfts to do its thing - is about where it has been? If so, at least that would tend to rule out clutch adjustment.
And it doesn't seem like you have clutch drag, as in a piece of a rubber centered clutch disk being where it shouldn't be. |
Agfours
I haven't noticed a change in the pickup point.
I would safely support the rear of car on jack stands and see if the wheels turn with the clutch pedal fully depressed and car in gear. if so your clutch is not fully disengaging.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Something is wrong with the clutch, and it might not be the cable. It's possible that the roll pin that holds the clutch pedal arm to the cross shaft in the pedal cluster is failing. Or, it's also possible that the throw out bearing release fork has cracked, just enough to change the clutch adjustment. FYI; your engagement point is too close to the floor for a properly adjusted clutch.
Keep the Shiny Side UP! Pete Z. |
Agfours
Oddly enough, just this morning before driving out of the driveway, I moved my seat by one detent and the perceived pickup point was much lower (the 1/4 travel upward). I later moved my seat forward to its usual position, and it seemed to my foot/brain that the pickup point was more like 1/2 way up....guess I need to get more scientific in my measurement.
FYI; call me old-fashioned, but I don't like the brass bushings for pedal clusters. I prefer the o.e. plastic parts only because they won't wear out the expensive metal parts that they rub against, and with the plastic there is no issue about what grease to use for the longest possible life.
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 11-29-2011 at 01:09 PM.. |
Agfours
RE: the comment on the type of grease to use, is there any issue using the typical lithium or teflon based grease on the brass fittings in your experience?
If your CC says Made In West Germany on it I will advise you to remove it ASAP and discard it. That cable will be an aftermarket version of the o.e. cable, and I've personally corrected many clutch linkage issues by replacing those cables (installed by others). I'm pretty sure our host has factory cables in stock, if not get one from your closest P-car dealer.
Agfours
I just wanted to post a follow up (have for some time, but finally getting around to it!).
I got under the car and checked the clutch cable, which to my suprise, was loose enought to where I could pull it off of the arm. I scratched my head a couple of times, as I swore I was very cautious when I had meticulously followed Bentley and 101 projects process to adjust initially. So, I decided to investigate further.... What I found was that the clutch pedal was not returning to the full upright position by about 1/4". I tied a string around the clutch pedal so that I could get under the car and see that the clutch cable was not properly adjusted once I pulled the pedal to full upright position (even with the brake pedal). So, I propped the clutch pedal in the full upright position with a large 22mm open end wrench against the firewall, and re-adjusted the clutch cable to specs. Seems that has corrected the issue. I did not end up rebuilding the pedal assembly, as it seemed tight, with no play in the bushings. Seems that the during the original adjustment, the clutch pedal was simply not returning to the full upright position, due to the return/helper spring reducing any slack, holding it in a slightly depressed plane... I'm not sure if the need to prop the pedal in the full upright position is just not well enough covered, is part of tribal knowledge, or if is an indicator of something else I'm overlooking, but hopefully this pays forward what I found in the process and can generate any further clarifications. Thanks to all for the spot-on advice!!
