kkinzli's Avatar
Painting undercoating question
Hi guys!
Just have a quick question about rubberized undercoating. I have most of the front end of the car in epoxy primer (PPG DP 40) and was wondering if is is okay to spray the rubberized undercoating directly onto the epoxy primer in the wheel wells and battery box area. What rubberized undercoating should I use? I have seen people talk about the Wurth and 3M products on the forum and was planning on going with 3M.
1969 911T - The "Rat"
1997 A4 Quattro 2.8 (270k) - Black Kaniget - Dead but not forgotten
2010 Jetta TDI Sportwagen - Egg Butt (also Spewing Dragon)
2001 Eurovan Weekender - Bruni
Old 02-12-2012, 05:42 PM
i just stripped my wells last week...
i sprayed two coats of self etch primer, let dry
then i sprayed two coats of epoxy primer, let dry
the used 3m rubberized undercoating in rattle can, worked great, came out perfect, used light coats, about 1.25 cans per well
what you see in the middle is seam sealer over the welded area for shock tower braces
Old 02-12-2012, 06:19 PM
kkinzli's Avatar
Thanks! That looks great!
Old 02-13-2012, 05:55 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Porsches I have painted have had the paint stripped to bare metal and then the pebble guard stuff applied but it was not factory. I am saying they were like this when I stripped them.
I have applied Wurth and Gravitex over 2 part primer and it has done just fine.
Old 02-13-2012, 06:17 AM
kkinzli's Avatar
Thanks Bob. I will hopefully get most of the front end done this weekend. Then for the daunting task of attacking the floor pan!
Old 02-13-2012, 09:46 AM
jsveb's Avatar
Jimtweet, do you mind sharing what brands, rattle can etc you used for self etch and epoxy?
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 02-13-2012, 09:58 AM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Sub'd.
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 02-13-2012, 10:06 AM
Registered speed offender
78SCRSMAN's Avatar
Wurth is the best and also what the factory used. The correct stuff comes in a plastic bottle and is sprayed using an undercoat gun. Wurth has a "special" gun but not necessary. I got a kit from Eastwood that came with some different wands etc. Personally, I would only use the spray can stuff for touch-up. I used 4 bottles on my car (fender wells only) but I would recommend getting 5 or 6 if you plan to do more than just the fender wells. I think the factory over did the undercoating a bit but more than enough can't hurt but too little is going to be a problem.
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Old 02-13-2012, 10:23 AM
Midwest R Gruppe
t6dpilot's Avatar
jimtweet, nice job! Curious on how you accomplished this. Is the car in full resto mode or did you do this with the exterior paint in tact? The rear fender well is so "funky" with tight areas and curves, I would suspect that it would be extremely difficult to get in all those tight spots. How did you do that? The reason I ask is that I am contemplating that project myself and would only be doing spot clean up of the rear wheel wells, not a full resto. It looks near impossible to get in all those tight areas without a media blaster.
Scott
69E Coupe 2.2S LtWt
73.5T Coupe
Old 02-13-2012, 11:44 AM
it took A LOT of patience and ALOT of time, i had a couple different angle grinders, different size wire wheels, torch, and some scrapers,...i worked a couple hours each night, i wasnt able to mentally take it all at once.
used :
Eastwood Self Etch Primer Gray & Black
Dupli-Color :: Primer Sealer
http://www.amazon.com/dp/B002H9CMCQ/ref=asc_df_B002H9CMCQ1899064?smid=ATVPDKIKX0DER&tag=hyprod-20&linkCode=asn&creative=395093&creativeASIN=B002H9CMCQ
before:
during:
after:
Old 02-13-2012, 08:40 PM
