911 Hi Beam Doesn't Work
With the headlights on the low beam works fine and the hi beam flasher works fine, but when I switch to hi beam driving position the headlights go dead. Fuses are good as indicated by the hi beam flasher working. Is there a headlight relay that I can't find or is that function part of the turn signal switch? Do I possibly have a bad t/s switch. Everything else controlled by the t/s switch works fine.
Old 02-18-2012, 09:07 AM
ROW '78 911 Targa
timmy2's Avatar
It is your turn signal switch.
Replace or repair, there are numerous threads here describing this problem.
An advanced title search will yield you numerous lengthy reads.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-18-2012, 09:20 AM
porwolf's Avatar
For starters here is one thread:
turn signal switch quick fix pictures
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-18-2012, 09:25 AM
lonewolf's Avatar
there is a high beam relay ,always check that first.
Old 02-18-2012, 09:30 AM
Thanks Porwolf. Those contacts may be the problem. Thanks Lonewolf....where is the high beam relay located on the car. Couldn't find it in the Bentley. Mine is a 79 911.
Old 02-18-2012, 09:57 AM
Honey Badger
theFONZ's Avatar
I just fixed a problem on mine where the high beams would come on when the turn signal canceled. It was the contacts in the switch being too close. If they were too far it would also cause your problem.
Old 02-18-2012, 10:05 AM
I'll be checking those contacts. I was thinking that mine might be too far apart preventing the hi beam contacts from making contact.
Old 02-18-2012, 10:41 AM
lonewolf's Avatar
Your year is not on a relay.
I'ts common for the plastic to melt and two contacts get stuck together ,
Old 02-18-2012, 11:26 AM
