Delusions of Adequacy
Uber-fanatic's Avatar
H4 Install...is it REALLY that easy???
I am looking for reassurance as I installed my new H4's last night and it all seemed a little too easy. Removing the sugarscoops was infinitely more difficult than reinstalling the new assemblies. For reference, in the past I've had to remove the sugar scoops for various reasons and it's always been difficult to get the aluminium ring back into place securely and to then get the bottom screw threaded. On my drivers side I had to go without a seal around the bucket because I couldn't get the sugar scoop on there if the seal was present.
That being said, imagine my surprise when I received my new H4's along with the prerequisite seal and they seated perfectly the first try. I started on the passenger side and literally starred at the empty bucket in shock when I realized that my new $200 investment was only held in the cavity by the smallest of lips at the top and the one screw at the bottom! At least the bulb assembly I removed was bolted into place with four stout screws...not 12 seconds later the whole new assembly was installed. Yikes. I banged on it with my fist ~lightly~ a few times just to see, but it sure seemed secure. Thinking this must be a case of beginner luck, I moved over to the driver's side of the car. 3 minutes later I was finished. Could it be that easy? Considering that the roads that I drive on daily are in such poor repair that my windshield wipers are constantly activated by fissures on the 5 freeway, how long before one of my new $200 investments comes leaping out of the bucket? As secure as they seem, anyone have any issue with them unwontedly extracting themselves at the most inappropriate time? Thanks in advance for any wisdom and/or reassurance.
1974 911 3.0 (makes me )
2004 Toyota Sequoia
2000 Honda CBR XX1100 Blackbird
Old 02-19-2012, 08:42 AM
motorcop's Avatar
Don't forget to upgrade the relay for the lights.
Old 02-19-2012, 08:46 AM
I stuck with the 55/60's to avoid needing the relay...I figured down the line I may install the more intense bulbs, and at that time I would install the relay; was I misinformed? I just went with the info from the tech forums recommendation as well as from the instructions on the actual site given by Wayne here.
2004 Toyota Sequoia
Old 02-19-2012, 08:52 AM
OttawaDave's Avatar
Others will chime in I'm sure, but the effort and expense involved with wiring some simp,e relays pales in comparison with the replacement of your high beams switch. Popular opinion seems to be pretty consistent that even with 55/60s, the relays are a good idea.
I swapped out my sugar scoops for the Bosch h4 units not too long ago...aside from the relay install, my experience was the same. Agree that the mounting system lacks a bit in terms of inspiring confidence though!
Old 02-19-2012, 09:00 AM
Point taken. I will order the relay's this week if others concur. Thanks for the input!
2004 Toyota Sequoia
Old 02-19-2012, 09:03 AM
RETIRED
Joe Bob's Avatar
The relay is a good idea even with low wattage....
2012 ML350 3.0 Turbo Diesel
Old 02-19-2012, 09:04 AM
Nine9six's Avatar
+1000 on relay install, even for the lower wattage!
You dont have to install the relays; but set aside an unending fund to replace hi/low beam/turn signal stalks as the contacts self-weld themselves together.
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 02-19-2012, 09:49 AM
kodioneill's Avatar
Some install a lanyard on the assemblies for piece of mind.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-19-2012, 10:15 AM
Registered Cruiser
jorian's Avatar
+1 on the lanyard. A zip tie from the back of the H4 to the inside of the bucket will save the assembly should it pop out. I have seen this happen at a track day. To add insult to injury, the guy ran over his own trim ring.
The seal and seat of the ring is critical to the fit.
I was considering an upgrade to some sort of HID unit until I did the relay upgrade which allows me to run 80/100 watts. Switched back to 55/60 soon after as the car looked like Wrigley field at night coming down the road.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 02-19-2012, 10:34 AM
Paul K's Avatar
+911 for the relay install. Almost as easy as the H4 upgrade, and well worth it. The relay takes the workload that the old switch isn't very good at taking.
I agree it seems like they're 'barely held on'.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 02-19-2012, 10:42 AM
Send a message via Yahoo to Lukesportsman
As a 911 owner, I found it humorous when Jeremy from Top Gear was destroying an old 911 (the only thing humorous) as he found difficult, the headlight falls out as he comes to stop in which he kicks it to the side. And I thought, not Porsche's most over engineered item.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 02-19-2012, 10:53 AM
Brandon-FL's Avatar
Not to hijack the thread, but I am going to be installing a set of H4s this week. Does anyone have a photo of the zip tie lanyard install? I like the idea and I'm wondering where you tie it off in the bucket and on the light assembly?
Old 02-19-2012, 11:53 AM
AV8TOR
How does one mount the h-4 bulbs????????
Greetings Fellow Pelicaners,
I too am a little confused about the H-4 install....
Below are pictures of a set of H-4s that I will be installing in a car in
the not to distant future. HOW do these H-4s mount. All I see is a hole
in the bottom of the trim ring where the "funky" screw goes thru
the bottom of your typical trim ring, there are no other mounting holes
that I see. Are there mounting brackets that attach to the rear of
the H-4 assemblies to attach to the 4 mounting tabs in the headlight
bucket
pokemon
Old 02-19-2012, 12:18 PM
nineball's Avatar
you may want to pick up one of fred's ato-style fuse panels with the relays built in. makes for a nice clean install and upgrades your fuse panel at the same time.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 02-19-2012, 12:19 PM
Relays are a good idea when running any halogen lights. They need good strong and tight connections, or they will produce a lot of heat.
Old 02-19-2012, 12:27 PM
+1
I've looked at these, and see one in my future...
This is why I love this forum! I will purchase the relay, probably install the zip-tie upgrade as it's cheap and affords some peace of mind, and then I'll look into the fuse panel replacement.
AV8TOR: Yes, the precariousness of the attachment is what made me post this in the first place. The entire assembly is held in the cavity by the small tabs at the top and the one screw at the bottom. Crazy when compared to how securely the previous bulb is mounted. I think I will take the suggestion of those in the know and finagle a wire tie onto the back and through the now unused bolt holes...I would really pain me to watch one come rocketing out of it's home and onto the 10 freeway...
2004 Toyota Sequoia
Old 02-19-2012, 12:49 PM
tanmanbgoh's Avatar
bump
1985 Targa 3.2 Black on black,16"Fuch,23 years California car.
Old 02-20-2012, 07:09 AM
1984 911 Targa - "Sabine"
Skip1's Avatar
Thumbs up
I installed the relay in about 10 mins (most of that was getting the carpet out too...). Well worth the investment, as I'd already had to clean up / service the highbeam switch on the column several times (which took me longer each time than it did installing the relay). Very clean with no fuss.
Skip
Old 02-20-2012, 08:17 AM
Sultan of Sawzall
rouxroux's Avatar
Yep, and they sure look better IMHO....here's a "1/2 and 1/2 comparison" from years ago:
Gruppe B #319
'66 Monza coupe 110/PG(white)
'95 993 cabriolet (wife's)
Old 02-20-2012, 08:25 AM
Spiderman
Jesse16's Avatar
And to add an option, the "combo" look. Old fashioned, 7" round reflector (albiet, a really nice Cibie unit), high wattage H4 bulbs w/relay kit, and the original trim ring, with a clear glass cover. Still the same minimal one screw hold-down method, still seems to work. Have a plan to body shop the trim ring and remove all the bolt holes except the bottom one. (have to do a little inside revision to firm up the mount and remove the adjust screws sticking out.)
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 02-20-2012, 09:01 AM
