1986 911/Targa
Question Dme relay
Hi,
I finally received the part! All I need to do is attach it. The problem is i don't know how.
I know that the DME relay is located under the drivers seat, and I've seen it. Can someone please tell me how to remove the old and how to put the new?
I was told that it's best to disconnect the battery first, is this correct? Then?
Old 04-24-2012, 01:45 PM
geoz's Avatar
I have a bolt holding it, once that is removed you just pull it out like any other relay. You can access it with the seat pushed backwards.
Old 04-24-2012, 02:06 PM
1986 911/Targa
Before I do, I must disconnect the battery, correct?
Old 04-24-2012, 02:08 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Dme
No.
Turn the key off, and just pull the relay.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-24-2012, 02:14 PM
1986 911/Targa
I got it to start. How cool is that !! Took me awhile , coz the seat was stuck. Even with my little hands it was kind of difficult to do it. But I did it. Ths s the first time I've done something like this. Thanks for all the help.
Old 04-24-2012, 11:14 PM
KNS KNS is offline
Congratulations!! You ought to but a second relay and keep it your glove box as a spare.
Kurt
Old 04-25-2012, 02:15 PM
steely's Avatar
That's very cool.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-25-2012, 04:18 PM
Detached Member
Hugh R's Avatar
Nice when its simple. Yeah buy another relay. On your seats, pull them out and clean the gunk out and put white grease on the runners. They work sooo much better. To get to the rear seat bolts, you get in the back seats and use your legs to push them all the way forward. Vacuum the crap out of the carpet while you're in there. Its about an hour job and well worth it once every decade.
Hugh
Old 04-25-2012, 06:05 PM
