-   -   Steve Wong Chip Advice (http://forums.pelicanparts.com/porsche-911-technical-forum/659959-steve-wong-chip-advice.html)
db_cooper 02-29-2012 07:24 AM
If this poster had fully read many posts, especially the last, he would have the simple
answer, "28 pins" - that's the latest version. But like many, didn't read and understand
what's posted and just love to be in the attack mode as most lemmings on this thread
was/are!
That is what I said, open it up..could be a 24pin, 28pin or an early 24pin soldered in chip...depends on what the PO installed without documentation....what is your problem Loren? Be nice..
http://www.redstaplerchronicles.com/...ychologist.jpg
andyt11 02-29-2012 07:28 AM
Originally Posted by Lorenfb (Post 6590801)
Some just can't read, even when they're given the answer!
You can hardly blame the guy. Most of this thread aint worth reading!!
Lorenfb 02-29-2012 07:32 AM
"That is what I said, open it up..could be a 24pin, 28pin or an early 24pin soldered in chip"
That's not what was posted:
"Remove and open the DME..take a look. Take some pictures and send to SW. I had the same question with a mystery chip and Steve was very helpful."
"Most of this thread aint worth reading!!"
I totally agree! Since most/all didn't provide any contributions, i.e. just attack.
db_cooper 02-29-2012 07:45 AM
Loren..be nice
Icemaster 02-29-2012 08:44 AM
Including you Loren.
Smoove1010 02-29-2012 09:30 AM
was/are!
28 pins - that's the answer I was looking for. Thanks.
db_cooper 02-29-2012 09:46 AM
http://forums.pelicanparts.com/uploa...1285774144.jpg
Our old machines can have some surprises. You may find one of these mystery DME chips, OEM or some other chip variant. Never know what the dreaded PO may have done.
88-diamondblue 02-29-2012 10:32 AM
Originally Posted by Lorenfb (Post 6587657)
O.K., here's one where you got lost in the technical details of a rebuild:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/260251-carrera-rebuild-10-3-pistons-cylinders.html
Now for the other ones.
How about this one:
http://forums.pelicanparts.com/porsche-911-technical-forum/478714-carrera-distributor-coil-connections.html
Like it really matters what's positive or negative.
http://forums.pelicanparts.com/porsche-911-technical-forum/326574-carrera-distributor-mechanical-advance.html
Oh, and here's the other insightful info about how the distributor controls the
timing in a DME ECM system. Don't really need a performance chip, just change
the distributor weights, right?
If your trying to make me look bad it is a big fail on this post just like it has always been. These threads turned into some very informative threads with the some of the top talent on this board sharing their knowledge with everyone here. Even you actually shared some good info on the distributor thread. It also shows how long you have been doing this crap, no change. Lorens business is to repair DME boxes among other things related. Would never do business with someone that attacks possible customers the way he does. Not if it was the last place to go.. Get to vote with my money. The first ban by Wayne wasn't enough for you?
dshepp806 02-29-2012 11:33 AM
mmm...let's see?....
.....(try this, Doyle): Is anyone here familiar with the timing (ignition) maps for the DME in the '88/'89? (As well as the pre-'88 DME?). If so, are you willing to share this knowledge?
How about the fuel maps, while we're at it?
I know they idled it higher.....why?
Thanks, in advance, for any information that can be provided....
Best,
Doyle
dshepp806 02-29-2012 11:35 AM
Interesting dB.......is this presently loaded in yours'? Performance Authority? What do you know about this one's particular programming?
Best,
Doyle
Smoove1010 02-29-2012 11:44 AM
Thanks for the photo. Now I know exactly what I'm looking for. I might have counted all the pins on all the chips otherwise.
I'm a newcomer to Porsche-world, but I have lifelong experience in a technology-driven business. I admit that I am swayed in favor of an updated factory unit vs. an older DME with a new aftermarket chip. The beauty of this forum is that all sides of the story are presented, sometimes... uh... "vigorously." Each of us gets to make our own decision and compare notes. It's a beautiful thing!
dshepp806 02-29-2012 12:10 PM
Looking "elsewhere", I found this: Performance Chips, What They Really Do! - Rennlist Discussion Forums (a bit dated but still relevant....).
Still looking to hear for the differences programmed for pre-'88 DMEs. If this ends up being "timing advances", we'll have a really good discussion.......
Best,
Doyle
dshepp806 02-29-2012 12:25 PM
some more from long ago:
Autothority chip vs the Steve Wong chip. - Rennlist Discussion Forums
Doyle
dshepp806 02-29-2012 12:29 PM
WOW: 3.2 Performance Chip Dyno Results - Rennlist Discussion Forums
Doyle
Steve W 02-29-2012 12:31 PM
I didn't really read all these posts, but being that this thread is about my chips, I'll tell you guys that you are truly wasting your time asking anything about tuning or the DME's operation from Loren. There are so many technical errors and assumptions in his posts, you can tell he's never tuned or seen a dyno in his life. You might as well as a blind man in a tittie bar how the ladies are.
Update a early 24 pin unit to 28 pin stock chip for the same change as a real performance chip? What a joke! Someone is trying to sell you a bill of goods. Bring some KY because it's going to be painful when you get bent over! All the units dyno the same power in the real world. It doesn't matter if it's an 84 Carrera with a 24 pin chip or a 89 with 28 pins. If installing a stock 28 pin chip achieved the same results, none of the thousands of 87-89 owners would have chipped their cars. This is how a stock 87-89 28pin chip compares to a true performance rechip, tuned on a Superflow engine dyno, stock 87 motor with nothing by a premuffler:
If you guys are looking for some of differences between all these chips, just go online here. It's been posted for years:
911Chips.com - Motronic Fuel Maps - Porsche 911
dshepp806 02-29-2012 12:31 PM
another wow: the extra memory space allows for maps of various "geographies"?
DME Differences - Rennlist Discussion Forums
Doyle
dshepp806 02-29-2012 12:37 PM
Getting closer......: Any differences b/w 3.2 liter 84-86 & 87-89 Carrera - Rennlist Discussion Forums
Thanks,
Doyle
Lorenfb 02-29-2012 01:01 PM
Yes, Doyle found it. Nice work. It contradicts what was just recently posted.
Yes, there is a difference! Read posts #2/#11. As mentioned before, just
drive a car with the pre-'88/'89 DME ECM and then with the later ECM,
the difference in noticeable.
Bottom line: The reality is that Porsche would not go to the extra cost of adding
a more expense memory device if there weren't resulting benefits - better driveability,
smoother idle, better O2 control, & more responsiveness.
db_cooper 02-29-2012 01:02 PM
Best,
Doyle
Presently I have the SW 91 octane with a cat/bypass chip..with his euro premuffler.
I could not be happier..fuel economy and the rump dyno results are very good.
My mystery chip..well, I sent it to SW for study, we think it was modeled after the late 3.2 programming and was someones great invention. I never could figure out who made it.:rolleyes:
Steve was very helpful and I appreciate it.
Lorenfb 02-29-2012 01:26 PM
"What do you know about this one's particular programming?"
The programming is here for the more common ones: http://www.systemsc.com/tests.htm
The tables explain everything!
