-   -   Saving the "Rat" - Restoring a 69T (http://forums.pelicanparts.com/porsche-911-technical-forum/660560-saving-rat-restoring-69t.html)
Lukesportsman 09-07-2012 08:49 PM
You desert rats just don't realize how lucky you are. Even cars that look decent in the rust belt have nothing up on yours when stripped naked. Enjoying the thread and progress. Nice story to boot.
Slow Steve 09-07-2012 08:54 PM
Looking good. Very motivating.
kkinzli 09-08-2012 10:30 AM
Thanks! You have to love NM!! Not just for minimal rust but also for the green chile:D
kkinzli 09-08-2012 10:31 AM
Thank you for the motivation sir!! Also looks like you are new to Pelican- Welcome aboardSmileWavy
kkinzli 09-08-2012 06:16 PM
Day 47: Today I was able to spray the final layer of the 3M undercoating on the floorpan! So excited that I am done with that!!
http://forums.pelicanparts.com/uploa...1347153184.jpg
Tomorrow I will be prepping the rear wheel wells to go to the media blaster. The space in the wheel wells is tight and I don't think that I can get my grinder in there sufficiently to deal will all of the rust. I figure since I am only doing this once I might as well do it right! Here are a few pics of what the rust looks like.
http://forums.pelicanparts.com/uploa...1347153295.jpg
http://forums.pelicanparts.com/uploa...1347153324.jpg
http://forums.pelicanparts.com/uploa...1347153357.jpg
95avblm3 09-09-2012 05:01 AM
^^^ I have rust (surface, I hope) in all the same places. Is there any way you could spot blast it? You're right though, better to nip it in the bud now.
By the way, has your dash cap arrived yet? How does it look? Post a picture of it? Thanks!!!
kkinzli 09-09-2012 11:21 AM
I could spot blast some of the areas but I could not get them all. In addition I will have the blaster get the hinge attachment areas and the front where the vin plate goes as that area would be a pain to do with a grinder.
Here are some pictures of the dash cap. It won't be as nice as a real dash but I think it is just the ticket for 8% of the price of a new one
http://forums.pelicanparts.com/uploa...1347214880.jpg
http://forums.pelicanparts.com/uploa...1347214894.jpg
http://forums.pelicanparts.com/uploa...1347214908.jpg
RWebb 09-09-2012 12:07 PM
looks pretty good in the pics!
95avblm3 09-10-2012 06:21 AM
Agreed... It looks great in the pics! How thick is it?
kkinzli 09-10-2012 06:30 AM
It is very thin plastic and is very flimsy.
strath44 09-10-2012 06:40 AM
wouldn't worry with some packing if needed for a good fit it will be fine, looks good from here!
Slow Steve 09-10-2012 11:38 AM
Looks good to me also. Where did you get it, mine is in need of one too?
kkinzli 09-11-2012 03:42 AM
I got it from Automotion. It is going to be an interesting install because I randomly have a 68 two piece dash in my car instead of a one piece 69 dash.
kkinzli 09-11-2012 11:33 AM
Does anyone know what type of seal I need to order for the chrome at the bottom of the popout windows? When I removed them I found a putty like substance that was placed in two lines on either side of the spacers. What is this putty and where can I get it? Today I placed one of my last orders from Pelican except for carpet and it included the following:
Rear window seal
Headliner clips
Rubber ends for headliner bars
Seal for air intake box
Fender seal
Torsion tube cover seals
I think I have almost everything stockpiled for the reassembly!!:):):D
DaddyGlenn 09-11-2012 11:40 AM
Originally Posted by kkinzli (Post 6969062)
{snip}...When I removed them I found a putty like substance that was placed in two lines on either side of the spacers. What is this putty and where can I get it? ...{snip}
It is called Strip Caulk. I got mine the same place I bought my paint.
DaddyGlenn 09-11-2012 11:42 AM
Here is a link... 3M Strip Calk 08578
kkinzli 09-11-2012 07:20 PM
Thanks Daddy Glenn! I was over on your thread earlier today and I must say your car is looking great. You have made some amazing progress:)
kkinzli 09-12-2012 05:34 AM
Was cruising around youtube last night and found this.
Steve McQueens Le Mans Porsche Auction - YouTube
Very inspirational and I am positive that slate grey is the right color for the Rat. I guess the only differences are that mine is a T not an S, there is no AC in the Rat, I am not going to have a radio, chrome wheel well trim, or front bumperettes, and the Rat is one year older. Also, I am not a cool baddass, just a nerdy engineering professor;)
I also watched this series (Made by Hand) which I think every Porsche enthusiast needs to see
Made By Hand - Part 1 of 5 - YouTube
Made By Hand - Part 2 of 5 - YouTube
Made By Hand - Part 3 of 5 - YouTube
Made By Hand - Part 4 of 5 - YouTube
Made By Hand - Part 5 of 5 - YouTube
95avblm3 09-12-2012 06:31 AM
I just watched part 1 of 5 of Made By Hand. Wow! It is quite amazing the advancement in fabrication techniques and manufacturing technologies over the last 50-60 years... yes, we have probably lost a great deal of the hand-craftmanship in the old cars but is that really such a bad thing? Repeatability is a good thing!
Daves911L 09-12-2012 07:54 AM
Kristoph,
For your strip caulk, go down to the nearest place that sells metal roofing materials. You can buy rolls of this designed to be placed under the overlapping roofing joints. It will be a flat ribbon about 12mm wide, and 3mm thick. If you need thicker, just apply extra layers. This material is not as soft as the 3M automotive strip caulk, and is very close to what Porsche used. It will flow under pressure, but tends to retain its shape and is very sticky. The 3M strip caulk is too soft and does not seal all that well.
As always, your work on the rat looks great.
DG
