-   -   Saving the "Rat" - Restoring a 69T (http://forums.pelicanparts.com/porsche-911-technical-forum/660560-saving-rat-restoring-69t.html)
BRPORSCHE 02-29-2012 11:23 AM
I love Bahia Honda.
And man this is a sweet project. Thanks for saving another one!
kkinzli 02-29-2012 11:25 AM
Day 11 continued:
Stripping and removing rust from gas tank. I made sure to blow out the fumes with my compressor and then run the car with a hose from the exhaust into the tank while grinding. I also duct taped all the openings
http://forums.pelicanparts.com/uploa...1330543359.jpg
http://forums.pelicanparts.com/uploa...1330543419.jpg
http://forums.pelicanparts.com/uploa...1330543449.jpg
kkinzli 02-29-2012 11:31 AM
Day 11 continued:
http://forums.pelicanparts.com/uploa...1330543632.jpg
Putting 3M undercoating over the dried primer - make sure to not let the primer dry more than a few days or else you have to sand it with 220 to get the undercoating or paint to stick
http://forums.pelicanparts.com/uploa...1330543753.jpg
http://forums.pelicanparts.com/uploa...1330543777.jpg
http://forums.pelicanparts.com/uploa...1330543807.jpg
http://forums.pelicanparts.com/uploa...1330543856.jpg
kkinzli 02-29-2012 11:35 AM
Day 11 continued:
http://forums.pelicanparts.com/uploa...1330543979.jpg
http://forums.pelicanparts.com/uploa...1330544015.jpg
http://forums.pelicanparts.com/uploa...1330544041.jpg
http://forums.pelicanparts.com/uploa...1330544063.jpg
Nice sunset and funny Padawan
http://forums.pelicanparts.com/uploa...1330544118.jpg
http://forums.pelicanparts.com/uploa...1330544140.jpg
kkinzli 02-29-2012 11:41 AM
Day 12: Painting gas tank
http://forums.pelicanparts.com/uploa...1330544300.jpg
http://forums.pelicanparts.com/uploa...1330544320.jpg
http://forums.pelicanparts.com/uploa...1330544340.jpg
http://forums.pelicanparts.com/uploa...1330544362.jpg
http://forums.pelicanparts.com/uploa...1330544391.jpg
http://forums.pelicanparts.com/uploa...1330544418.jpg
http://forums.pelicanparts.com/uploa...1330544447.jpg
kkinzli 02-29-2012 11:48 AM
Days 13 and 14:
Before
http://forums.pelicanparts.com/uploa...1330544697.jpg
http://forums.pelicanparts.com/uploa...1330544738.jpg
http://forums.pelicanparts.com/uploa...1330544788.jpg
http://forums.pelicanparts.com/uploa...1330544820.jpg
http://forums.pelicanparts.com/uploa...1330544840.jpg
http://forums.pelicanparts.com/uploa...1330544867.jpg
kkinzli 02-29-2012 11:52 AM
Day 13/14: Painting shocks
Before and After
http://forums.pelicanparts.com/uploa...1330545099.jpg
http://forums.pelicanparts.com/uploa...1330545160.jpg
http://forums.pelicanparts.com/uploa...1330545002.jpg
http://forums.pelicanparts.com/uploa...1330545037.jpg
kkinzli 02-29-2012 11:58 AM
Day 13/14 continued:
Refinished gas tank clips
http://forums.pelicanparts.com/uploa...1330545352.jpg
Primer on bottom of front pan and fender attachment points
http://forums.pelicanparts.com/uploa...1330545399.jpg
http://forums.pelicanparts.com/uploa...1330545450.jpg
http://forums.pelicanparts.com/uploa...1330545494.jpg
kkinzli 02-29-2012 12:04 PM
Day 13/14 continued: Stripping doors and hood
Both the hood and the doors are at the body shop right now for work. My welding skills are fairly rudimentary so I didn't want to warp the doors and the hood. I am planning on welding all the replacement patches in the front of the body with Peter this coming weekend
http://forums.pelicanparts.com/uploa...1330545717.jpg
http://forums.pelicanparts.com/uploa...1330545753.jpg
My new fiberglass front bumper! The old bumper is up for sale is anyone is interested:)
http://forums.pelicanparts.com/uploa...1330545845.jpg
RWebb 02-29-2012 12:09 PM
Originally Posted by kkinzli (Post 6590488)
Civil engineering, specifically water resources, fluid mechanics, hydrology, hydraulics, river mechanics, and design
wow -- big change from NM to FL
BTW - what is your desired end point for the car? maybe I missed it...
Concours?
Period Correct?
Hot Rod?
"Just a Driver"?
I guess we can rule out Rat Rod...
kkinzli 02-29-2012 12:09 PM
Day 15: Rebuilding pedal cluster and brake master cylinder
Before (I had already replaced all of the bushings at Obi Wans!)
http://forums.pelicanparts.com/uploa...1330546007.jpg
http://forums.pelicanparts.com/uploa...1330546030.jpg
After blasting and Ospho
http://forums.pelicanparts.com/uploa...1330546086.jpg
http://forums.pelicanparts.com/uploa...1330546105.jpg
http://forums.pelicanparts.com/uploa...1330546128.jpg
Primer
http://forums.pelicanparts.com/uploa...1330546160.jpg
kkinzli 02-29-2012 12:13 PM
Day 15 :
Brake master cylinder after blasting. I used old bleeder screws and caps to keep sand out of everything
http://forums.pelicanparts.com/uploa...1330546381.jpg
Pedal cluster and brake master cylinder after paint
http://forums.pelicanparts.com/uploa...1330546286.jpg
http://forums.pelicanparts.com/uploa...1330546308.jpg
kkinzli 02-29-2012 12:16 PM
Alright, that brings us up to the current state. I will try to post progress pictures from work days on a regular basis!
kkinzli 02-29-2012 12:19 PM
Originally Posted by BRPORSCHE (Post 6591245)
I love Bahia Honda.
Thanks! We love it too! It will be a while before it is saved:(
kkinzli 02-29-2012 12:25 PM
Concours?
Period Correct?
Hot Rod?
"Just a Driver"?
NM to FL was indeed a big change. Mainly we were not used to the palm trees and all the old people;) In terms of the car I am staying as period correct as possible and hope to end up with a solid driver for daily use. Mechanically the car is pretty well sorted out and it is just a rust removal and protection project right now. There is no way I could do concours - I am an engineer and am much to pragmatic for that;) and I don't have limitless time or funds to do so. Also, I already miss driving the car and it has only been 5 weeks since I started on the repaint and rust restoration
RWebb 02-29-2012 01:04 PM
I was thinking of the hydrology, but the cultures are quite different also.
Early 911S bbs can help with any tricky details on period correctness.
I am somewhat pleased to hear it wll not be limited to being a concoursmobile... BTW, my car is period correct, but which period depends on what part of the car you are looking at...
http://forums.pelicanparts.com/porsche-911-technical-forum/273740-yet-another-boring-hot-rod-rgruppe-car-part-v-exterior-paint.html
Enjoy the 901 type trans. on your car - it has a much better feel & shift layout than the later 915.
matt gineo 02-29-2012 03:32 PM
I just finished cleaning the inside of my fuel tank and getting ready to paint the exterior. Did you spray the tank with 3m undercoating first then paint over it with gray paint. I thought you could not paint over undercoating. What type of paint did you use? Great project, really enjoy your documentation.
kkinzli 03-01-2012 04:39 AM
Hi Matt,
Thanks, glad you are enjoying it! First, I got rid of the factory schutz in questionable areas where it had cracked or had any rust on it. This ended up being most of the tank. The worst part was the seam where the two tank halves are joined together. Once I had the schutz off I did wire wheel and ospho (overnight) multiple times to get down to clean shiny metal. I also used the blaster intermittently during this process. Once I had it down to bare metal I did one more application of ospho and let it sit for about an hour. The trick to ospho is that you need to do several applications overnight to really get at the rust. The last application of ospho is to create a zinc coating similar to what DX 520 from PPG does. After about an hour for the last application of ospho I wiped everything off with a towel and let the tank dry. The next step was two coats of PPG DP 40 epoxy primer applied with a brush (drying times are listed on their spec sheets). The final step was to spray three coats of the 3M undercoating (you can get this from Autozone etc) on the tank. Good luck and make sure to run a hose from your running car exhaust to your tank as the fumes from gas in the tank can blow up the tank
kkinzli 03-01-2012 05:21 AM
The hydrology here is incredibly different. We get about 60 inches of precipitation (Colorado gets 14 and NM about 9). There is no topography to store the water in reservoirs so groundwater is being mined and the aquifer is declining. This leads to saltwater intrusion:( On top of the problems we already have everyone wants to retire here and we have a huge influx of new residents. Everybody also want to play golf and each game played in the state of Florida requires about 3000 gallons of water to keep the course green during the dry season:mad:
The Rat will never be in any type of car show! I think it is absolutely asinine for people to spend a ton of money to restore their cars and then only bring them out to show them off. These cars are meant to be driven and driven hard. Pretty sure that Dr. Porsche and Ferry would agree as they were always pushing the limits. I think it is a crime both for the owner and for the car to not put miles on these awesome machines. Your signature says it all. As everyone on this forum knows, half the fun is replacing stuff when it breaks or wears out.
I don't mean to sound rude to some of the concours people (or baseball card people) but I just don't get it. It reminds me of my childhood when the neighbor kids collected all these amazing baseball cards and put them in special cases and were not even allowed to touch them. They moved the cards around with tweezers and were always showing off that they had this card or that card to feel special and important. They were always so sad when they got a card through the mail that had a bent corner or a tiny little scuff that made the card less valuable. The book they used to look up the values was also quite amusing. Instead of playing with baseball cards I just played baseball or soccer in the cul de sac in front of our house and broke the requisite number of windows, gutters, and garage doors ;). There was also a group of kids that collected action figures and never took them out of the package! I think having a poor concours P-car is similar to having some GI Joe languishing in a plastic package. Neither one can kick ass like they were meant to!
matt gineo 03-01-2012 06:16 AM
Thanks, It sounds like I'm doing exactly the same thing you're doing with the tank. First I cleaned the inside of the tank, including the plastic swirl pot (I don't think you have one of these) I had to cut a hole in the top of my tank to remove the top of the swirl pot and clean everything out. I then fabricated a stainless steel access plate to cover up the hole. Once I had everything cleaned out I coated the inside with Ospho and let it dry.
I was confused with your photos, it looks like the gray paint is the primer and black is the 3M undercoating? I tried finding gray undercoating but didn't have much luck so I used Black 3m undercoating too. I guess the concours police will delete a few points for unoriginal fuel tank color.
