Rev-limiting rotor
Anyone know what the specs are for these rotors? I see nothing available for any 911 from 78-83 except the turbo RL rotor - (Part # 930-602-901-01-M14, Pelican Parts - Product Information: 930-602-901-01-M14 ). I think the SC's have something up in the dash that acted as a cutout but not sure if that works or not so if I can toss the turbo part on that will work. Also like to know what the rev limit is on these rotors,,
Gary R. |
Gary,
Yes, the 911SC has a rev-sensing box (J35 “Speed Switch”) that cuts off the fuel pump. No rev-limiting rotor. Has anyone made this adjustable? Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Thanks Grady - Will the turbo rotor fit/work in the SC distributor? Do you know what the RPM cut-out is for the "J35" and the RL rotor?
Gary R. |
Go Speedracer, go!
Euro SC do not have a rev limiting switch in the dash. I use the turbo rotor for my euro sc. It's a 7200 rpm cutoff. The cutoff is printed on the rotor.
1981 SC ROW Coupe |
Thanks, i'll pick up a Turbo rotor, assume our dizzys are identical..
Gary R. |
RETIRED
My euro had that rotor and I used a turbo one.....there are different rev limits. They are inscribed on the rotor.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Anyone get one from here? I see no choice in rev limit..
Gary R. |
I have the rotors in stock Your car should still have the rev limiter box in it
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R DanielJacobsLLC.com |
Thanks Dan, servicing her now, switching seats around, fixin a couple little things then I think she will come in to run a quick alignment/balance on her if you have time..
Gary R. |
Since the euro and turbo rev limit is higher than the US spec SC, you may not want to go the rev limiting rotor route as PCA is planning to check rev limits more than in the past.
I believe that "J35 Speed Switch"is NLA so there is no choice in the matter AFAIK, but in the end I leave it up to my shop to make right and meet the rules.
Gary R. |
I am going to disconnect my functioning J35 and replace it with the turbo rotor since I have converted to Euro spec, let me know if you need it and I will bring it to the Glen.
Speed Dog's Chauffeur
RPMs
Turbo rotor (BOSCH 1-234-332-223)is 7000 RPM and about 1/2 the price of the Euro (BOSCH 1-234-332-240) is 6800 RPM. I have used them for years on an early 3.0 conversion. Not perfect but functional. The factory cut off fuel to save the TE or CAT from clogging with raw fuel.
Has someone looked into the rev-sensing box (J35 “Speed Switch”) and documented the circuit?
If someone has the circuit diagram, it should be easy to have the rpm cut-off adjustable. Does someone have a defective one I can have? I'll produce a diagram. Best, Grady
It sounds like the Turbo rotor (one guy said 7200, one said 7000 RPM) may not be legal for you if their is a special (2x the $!) 6800 RPM Euro rotor available.. Grady - depending on what my shop does you are welcome to mine as it was cutting me out at anywhere from 5500-6000 and is NG as-is..
Gary R. |
I was under the impression that the Euro rotor is NLA, where can i find one? Since the rev limit specs have a tolerance of +- 200 rpm, the turbo rotor could work for a Euro SC and be club race legal but you never know. Does yours cut in at 7k or below?
For real though, it actually cuts in at the top of the tolerance range, perfect for a D car, I haven't switched it out yet because we wanted to keep the revs down a bit during engine break in.
Gary, you have email.
Guys, There are ± trade-offs between the SC fuel pump cut-off rev limiting and the rotor type. The electronic cut-off is probably better for track use where you regularly approach (but never touch) the rev limit. The fuel pump cut-off never comes into play unless you err by revving a bit more. With the rotor type, the engine begins to misfire as it approaches the limit. This can be as much as 500+ rpm below the stated limit. Testing on an engine dyno, I can detect the misfire sometimes as far as 1000 rpm lower than specified. On dyno runs, I always installed a non-rev-limit rotor. For street use, the rotor type gives a ‘softer’ limit to the revs as you can feel it over the preceding 500 rpm or so. The electronic fuel pump shut-off is very sudden and abrupt, causing the engine to off/on/off/on rapidly. Best, Grady
Got it Grady, let's see if Dan can get mine working. If not it's yours else if he does maybe Frank will donate his!
Gary R. |
Euro not easy to find anymore
PELICAN: OEM-93060290102 (1 234 332 240) Genuine Porsche Part: DISTRIBUTOR ROTOR- This is a special-order, non-returnable, Porsche part (availability and shipping charges may vary). $51.00 EURO REFERENCE: Rotor, distributor Porsche 911 from Bosch - 1 234 332 240 |
