Banned
Picture request - Fuchs without paint, but not polished.
IIRC, Fuchs come factory-anodized, and the centers painted. Some folks strip off the paint, then polish. Well, maybe some of you have stripped the paint, and then NOT polished!. That's what I'd love to see pictures of, please.
TIA!
Old 02-25-2012, 09:14 AM
cdrik915's Avatar
Hi ,
2.4 E / 72' Fuch.
Stripped with Caustic soda. (used for wc)
Not polished , just stripped.
LIGHTER = FASTER !!!
Old 02-25-2012, 09:21 AM
Rescuer of old cars
Arne2's Avatar
Sub'd. I'd like to see more examples as well. Especially any later black centered with the black stripped, but the anodizing still intact.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-25-2012, 09:31 AM
Banned
Originally Posted by cdrik915 View Post
Hi ,
2.4 E / 72' Fuch.
Nice. That wheel looks good.
Old 02-25-2012, 11:03 AM
Is the anodizing still in place under the paint? Mine have all black paint but I'd like to go back to the natural petals if the anodizing is under the paint.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 02-25-2012, 01:43 PM
Josh D's Avatar
Not all Fuchs have anodizing under the paint. When I stripped the paint on my 16x7, there was no anodizing underneath, just on the lip. The 16x6 on the front had anodizing under the paint, but it didn't look good enough to leave as a finish so I stripped it off and did a semi polish. I don't. Believe my Fuchs are original to my car.
Old 02-25-2012, 02:11 PM
Gordo2's Avatar
Blast Centers With Polished Lip
I media blast my wheels and polished the lips with intent to paint the centers black. I didn't get around to painting due to a hot/humid summer, so I installed them that way. I kind of liked the look and left them that way for about a year before I finally painted the centers black.
Not a bad look.
Don "Gordo" Gordon
'83 911SC Targa
Old 02-25-2012, 11:26 PM
Gordo2's Avatar
Wheel Close Up
Close up of the wheels post polishing.
Don "Gordo" Gordon
'83 911SC Targa
Old 02-25-2012, 11:34 PM
Reiver
Reiver's Avatar
Gordo, looks like the older mag wheels
Old 02-26-2012, 07:47 AM
How do you remove the black paint without disturbing the outer anodized rim? When using soda, can you block off the unpainted areas without damage?
Jim
79 911 SC
Old 02-26-2012, 09:47 AM
techweenie's Avatar
The original anodizing on street wheels was a dipping process, so its unlikely that there's 'un anodized' material under the paint.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 02-26-2012, 12:06 PM
Banned
This is exactly how my cast replica Fuchs look after stripping the center paint.
The texture on the centers is a little less rough, but not by much.
Old 02-26-2012, 01:57 PM
Rescuer of old cars
Arne2's Avatar
I've heard people say that the later black center wheels did not have nice prep on the petals under the anodizing, and so after stripping the paint (but not the anodizing) the petals don't look as nice as the anodized rim. No one has posted a picture of that yet, which is what I was hoping to see. I guess I'll need to break out the stripper and do one of mine to find out for sure.
2018 718 Cayman 2.0
Old 02-26-2012, 02:22 PM
Banned
Make sure you post a picture of her (the stripper) for us when you do break her out.
Thanks.
Old 02-26-2012, 02:34 PM
porwolf's Avatar
That sounds right to me. It is my understanding that the black part of the original anodized finish is actally also anodized, not in clear but in black. The wheel's original black centers are not painted. Anodizing can be done in any color by adding ink to the process. But I don't know how the masking for the Fuchs's is done.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-26-2012, 02:40 PM
Formerly known as Syzygy
Canada Kev's Avatar
I believe that the lips were actually finished much better prior to anodizing than the centres that were going to get paint. After the anodizing process, which involves dipping the wheel in a (likely acidic) solution, the black portion of the wheel was painted. It was not anodized black. Since the factory was going to paint the wheel centre, having the nice, smooth finish wasn't a priority, thus the rougher look under the paint. It is, however, still anodized. Well, unless it was damaged or removed in the paint stripping process, that is...
Kevin
Old 02-26-2012, 03:31 PM
Gordo2's Avatar
Fuchs Surface
I didn't think there was any noticeable difference in metal finish after stripping - the petals were the same as the outer ring. This may have been due to the abrasive that I blast them with though.
In progress of polishing:
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 02-26-2012, 04:43 PM
Josh D's Avatar
All I can say is when I stripped my 16X7's with AC paint stripper, there was no anodizing under the paint. The anodizing on the rim/lip stayed intact. You could clearly see the difference and I was able to go right to polishing the petals on these. I'm not making this up.
This was not the case with the 16X6. After stripping the paint, which was much, much more difficult, it was anodized underneath. I mechanically removed the anodizing on these to get to the polishable aluminum below.
I believe the 16X7 and the 16X6 on my car are possibly from different years as they are not original to my car.
I'm just guessing, but somewhere in the timeline the anodizing process changed.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 02-27-2012, 09:44 AM
techweenie's Avatar
Yes, Kevin's answer is spot on. The anodizing is called "clear" and is evident on polished portions of the wheel. It is not evident on the unpolished portions (the centers). The anodizing adds a subtle "grain" to the finish turning a polished surface into a "satin" surface. On a rough surface, the anodizing is not noticeable to the eye.
1969 coupe hot rod
Old 02-27-2012, 10:03 AM
Rescuer of old cars
Arne2's Avatar
I stripped the black paint on couple of mine over the past week, and can confirm that the petals did not get much finish prep prior to paint. Fine sanding marks and other finishing remnants were very evident. I didn't bother stripping completely, just wiped with lacquer thinner and a rag until I could see what was underneath. I forgot to take pictures, but take my word for it - if the centers were factory painted, they will require additional finish prep of some sort to be suitable to be unpainted.
2018 718 Cayman 2.0
Old 04-17-2012, 08:59 PM
