dshepp806's Avatar
Gauge bezel removal tool,..got pic?
(a cross-post from R/L):
Has anyone a pic of the tool that's used to remove the instrument gauge bezel? (Please, spare me the pics of screwdrivers and such.......!)
Just curious as to what the shops use.
Thanks!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-23-2012, 01:51 PM
porwolf's Avatar
Good question, like to know also.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-23-2012, 02:05 PM
Burnin' Rubber
Koizumi's Avatar
If that info was released to the public, "they" would lose a lotta biz :-)
Old 02-23-2012, 02:13 PM
I wonder if something like a piston ring compressor would work. Seems like you just need something to wrap around the guage that you could then tap gently on. Of course holding the gauge in place while working on it is probably the most difficult part.
Old 02-23-2012, 02:19 PM
porwolf's Avatar
Could it be that the gauge repair shops use some kind of a lathe arrangement where they clamp the meter in, rotate it slowly, and use an appropriate stationary metal thorn to slowly open it up in the back, and work the trim ring lose? Then do something in reverse to reattach the trim ring?
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 02-23-2012, 02:24 PM
kodioneill's Avatar
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 02-23-2012, 02:56 PM
emac's Avatar
81SC removed all of them just by twisting and slowly pulling out. Had one tight screwdriver with tape on edge just to pry out. No bog issue.
Ernie. 81SC
Old 02-23-2012, 03:03 PM
kodioneill's Avatar
Ernie. 81SC
I think he means the trim around the gauge not the gauge itself. They're are a ***** to remove.
1982 chiffon 911sc
Old 02-23-2012, 03:06 PM
dshepp806's Avatar
I've repaired a few odometers in my day,...no problem getting that ***** off,....but was just curious to see a pic of the tool, itself>,..as I do believe it exists...bet it does it quite cleanly.....
Best,
Doyle
Middle Georgia
Old 02-23-2012, 03:14 PM
Wash. State
nesslar's Avatar
When it's done carefully (with a little experience) and then replaced into the dash, nobody would ever know...........easy. Done it many times.
Old 02-23-2012, 04:17 PM
dshepp806's Avatar
well,..of course.
Now,..for the pic?
Doyle
Middle Georgia
Old 02-23-2012, 04:44 PM
Wash. State
nesslar's Avatar
OK; posted it previously, actually...you can search it; odo replacement threads with my username attached. It turned out great. Ask around...
Old 02-23-2012, 04:49 PM
Wash. State
nesslar's Avatar
Can someone post a picture of your speedometer?
This is the one I just found; difficult search, but this was my 1st effort at odo gear replacement; it ain't that tough, just have to be careful...
Old 02-23-2012, 05:04 PM
Wash. State
nesslar's Avatar
Just need a screwdriver (small) and patience...and 'touch'...
Ask around, I've done a few for guys, they are happy........................................
Old 02-23-2012, 05:09 PM
a quick google search.
206 637 4071
Old 02-23-2012, 05:14 PM
Wash. State
nesslar's Avatar
...bet that's cheap if even available...
Hell, even in '101 projects' by W., there are notes about how this process works; who cares about a few 'dog bites' that never show though, right?
After a few efforts, even the 'damage' is so minimal as to be considered negligible, and only is seen if you pull the gauge back out! The rubber 'grommet' covers all if done correctly. It's less than a couple hours work to replace the odo gear AND sync the speedo....easy.... I know.
Old 02-23-2012, 05:20 PM
Fleabit peanut monkey
Bob Kontak's Avatar
This supports nesslar's info. Pics too.
Pelican Technical Article: Porsche Dashboard Gauge Repair and Refurbishment
Old 02-23-2012, 05:24 PM
Wash. State
nesslar's Avatar
... The first pictures (older speedo) done by me for "Mike" IIRC, and looking at the 2 pix, you can see that it is in MY DASH, and has been tested over a half-mile jaunt with success. Also, you will see that the thing looks like it has never been out of the dash.... all good. The latter, my own, the next pix of the 67K mile thing, equally ok... .....the grill? you tell me. :I $175 shipped....
Old 02-23-2012, 06:21 PM
Walt Fricke's Avatar
A craftsman friend had figured out a way to notch a small screwdriver so that pushing it around under the lip of the bezel neatly spread the lip out. But I don't have a picture of that.
The tools shown look more like they are for rolling a new bezel on. Would work for an old one also. What I recall from posts is that VDO won't sell new bezels, at least not to anyone not an instrument shop.
Old 02-23-2012, 09:08 PM
Burnin' Rubber
Koizumi's Avatar
Does anybody sell just the glass? Some of my gauges are plastic. I'd like to swap 'em for glass.
Old 02-24-2012, 12:10 AM
