"stuff" on twin plug distributor rotor
Is anyone familiar with the "stuff" that is on the rotor of this twin plug distributor? It's hard like epoxy, but it does not appear to be epoxy. It's on both a new and used Jarvis distributor.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 03-02-2012, 09:42 PM
Max Sluiter
Flieger's Avatar
I guess it could be epoxy for balance but that seems like a rather crude way to do it.
Old 03-02-2012, 09:59 PM
I was wonder about balance too. The other dist is exactly the same. It doesn't seem as heavy as epoxy though, yet hard like epoxy.
Old 03-02-2012, 10:03 PM
Max Sluiter
Flieger's Avatar
Did you try contacting the manufacturer?
Old 03-02-2012, 10:05 PM
tadd's Avatar
Jarvis tech
Their all like that, even the early test mule twin plug unit I've got. I think it's there to insulate the lower lead since it's not 180 from the top lead anymore and out from under the plastic of the jag rotor.
I was appalled when I popped the cap the first time :-).
t
1967 912 with centerlocks… 10 years and still in pieces!
Old 03-03-2012, 08:24 AM
