Transmission jack for Engine and tranny removal
I'm getting ready to do my first drop and looking at the options. has anyone tried this Harbor freight scissor type transmission jack for a engine and tranny drop? It looks pretty good with no handle to get in the way like the motorcycle lift jack and the price seems right. Transmission Jack - 450 Lb. Capacity
Paper Member
You'd be seriously pushing the weight limit of that jack.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
I love harbor freight as much as many of the members here but when it comes to my safety I dont trust them in any way shape or form. I have plenty of tools from there and they have lasted me far longer than people seem to think they last and helped me with plenty of repairs. But all of my jacks, jack stands, and other serious load bearing tools come from more reputable sources. I also have made a habit of using a bit of overkill (max load limit is always greater than max load) when it comes to jacks just to be safe.
Let this be a staunch reminder of what happens when you go over a weight limit https://www.youtube.com/watch?v=pjw2gQEBSc0 Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
Champagne on Beer Budget
Einar www.einarsgarage.com Instagram @einars_garage https://www.facebook.com/pages/Einars-Garage/375533809160797 |
It would not lift the 5 speed in my Rx-7 without binding up.
Rick 88 Cab |
I appreciate the feedback guys! What is a good figure to use for a combined weight for enginee and transmission ?
Paper Member
I think most engines are in the 450 lb range and a gearbox is maybe 75 to 130 lb depending on the type. Those are guesstimates
'79 911SC Targa
I don't know if this helps but here is a suggestion.
For my first drop, I bought a furniture dolly, added 2- 2x4s to the center and then a 1/2 piece of ply wood on top. The additional 2x4s added the support needed for the center section of the plywood. This worked well for the drop and also gave me a nice platform to move and work in the motor once it was out. Here is the part you need to consider no matter what you choose: For me, once the engine and transmission was ready to come out, meaning all that was left was to loosen the mounts, we lowered the car almost all the way down and rested it back on the lowered jack stands. The result it that the engine is only a foot or so above the floor. Then we placed a floor jack under the dolly (at the reinforced part) and raised it up to the engine. Once all the mounts were loose and we were happy that it was stable we lowered the whole thing straight down to the floor. We then lifted the car back up high enough to pull the motor out. This approach really limits the height you need to "drop" the engine not matter what you choice to hold it. Good luck with it! |
Tom |
i use a tranny jack for engine drops. works GREAT! i like it because the jack plate can be adjusted so it tilts to the angle of the engine. the other main advantage is it has 4 wheels that swivel so i can move the engine in any direction under the car to line it up when putting it back in. thats probably the biggest advantage. it also has chains so you can chain the engine to the jack. i also use it to lift the car higher to get the engine out from under it.
i also use it because i made the mistake and bought a big some *****(jackie gleason) a long time ago so i need to use it for something.
I use a Sears ATV jack with a couple 2x4s under the headers and a ratcheting strap on the front to keep it level with the trans attached. Easy to move around, adjustable for height, very stable.
Gary R. |
Spiderman
The ATV/motorcycle jack works great. You can get them at lots of places, Northern Tool included. What I've used. If you aren't using a full car lift system, you really don't lift or drop the engine much, more of a lift the car off or drop it on the engine with the jack just making up a short space.
Midnight Blue 08 Cayman S, Fun/Track Black 12 VW-GTI, work Mexico Blue 87 Carrera, sold, sad, not enough garage space. |
that jack has a nice big platform forthe motor but the tranny jack has 4 wheels that swivel. makes it soooo much easier to line the engine up to bolt it in.
another thing to consider is how hi the jack goes. you either have to get the car hi enough to roll the engine out, then you need a jack that goes hi enough to reach the motor, or once you drop the motor you have to raise the car.
The best ATV lift is this one from Sears. I originally bought one from HF but took it back
when I saw the quality of the Sears unit. I got a furniture dolly and replaced the swivel casters with much taller ones. I then could place the dolly on the Sears lift and lower the motor/trans. I then was free to slid the lift out and use the dolly to roll things around. The Sears lift has much better and precise control when you release the valve to lower things (a shortcoming of the cheaper lifts) It also controls the lift like a floor jack with a "twist"shaft, instead of a foot pedal like the lesser units, plus it's aluminum and much lighter. It is a few more dollars ($54 more than the cheaper red Craftsman), but you will have it forever. When I buy tools, I always reread a little laminated card that I keep in my wallet that reads: "The bitterness of poor quality lingers long after the sweetness of low price is forgotten" I then act accordingly!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 04-30-2014 at 12:41 PM.. |
I have the red craftsman ATV jack.
While it is nice, I would love to have 4 casters that can turn. Dropping the motor and trans is a task that you will want to do slowly. The ATV jack allows you to do that, and you don't have to attempt to balance it on a "jack pad" as seen on typical floor jacks. Regarding the HF special: your engine and trans is full of (carefully crafted) things that will be damaged when the HF jack fails. For that matter, I have some tools (not too many) that I have purchased from HF, and they are for what I consider "disposable" purposes. If I trash a multimeter from HF, I can throw it in the trash not angry for testing something improperly. Things like jack stands, jacks, lifts and such are craftsman (at a minimum) in my garage. Here's the best part: keep an eye on craigslist, ATV jacks seem to be items that people let go of for cheap. I scooped mine for $80. Good luck!!
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
![]() Perhaps the OP could hire the atv type for the job,unless he has a lot of use for one this would be a cheaper option.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in. Past cars, 17 aircooled VW's and lots of BMW's KP 13/3/1959-21/11/2014 RIP my best friend. |
Here is a picture I posted on Facebook - Here is the URL:
https://scontent-a-iad.xx.fbcdn.net/hphotos-ash3/t1.0-9/27110_110673295634757_5928944_n.jpg
SteveKJR Proud Owner of a 78 911 SC Targa "A Porsche does more then just go fast in a straight line" |
I have been looking for something like this as well, has anyone used the adapters for a floor jack that are available?
The ATV jacks are all way too low- they require you to use a crane to put the motor on the P201 for the stand.
Use the hydraulic lift table and you don't need a crane anymore-- you can R&R the motor, put it on the stand, or even put it in the back of a standard pickup truck with the table (ford Ranger or something low, not something with a 6" body lift) And be careful you can kill or dismember yourself with these things
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I did the R and R with a transmission jack, and it was a bear to do it all alone. Then I got the jack adapter from our host, and it is SOOOOO much easier (and safer)
1979 Porsche 911 SC Coupe - Tools - Page 6 |
