Should I get some trim?
Just back from the painters a d a question came up before final spray.
Will I be using the aluminum trim peice the sits beneath the rear 1/4 window, or leaving it off, Plugging the body holes and painting t It smooth? This will be a frequent all (summer) weather almost daily driver street/track car. In every pic I have looked at the angle is too low to tell if other hot rods are running this trim I assume that I need to run the door window trim (top of door skin) and without this rear peice it ends abruptly Feedback?? Thanks |
it matches up to the door top trim, so i would leave it on for aesthetics, as well as the fit of the rubber seal on the glass. probably be a gap without it. remove it for paint though. don't forget the caulk under it to keep water out of the interior. keep the plastic spacers in order too.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 03-06-2012 at 01:01 PM.. |
Recreational User
It would look terrible without it. Definitely leave it on.
Thanks guys!
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
