Weekend Mechanic
vulcan300's Avatar
Should I replace my fan housing?
Thanks to some mouse related issues I had to remover the fan and fan housing from my 86 targa. After removing it I discovered that the fan housing cracked in many places (pictures below). I drove the car for two solid summers after I bought it and never had a problem with the fan. Should I just reinstall it and hope for the best, or should I find a used replacement?
86 911 Carrera Targa
Old 03-05-2012, 03:49 PM
DUK DUK is offline
DUK's Avatar
That looks quite excessive. I think I would scrap it and look for a better one. Or do what I did and get a vertex.
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 03-05-2012, 03:56 PM
911t Fanatic's Avatar
Time for a new/used one. That one has served its pupose.
Old 03-05-2012, 03:57 PM
David's Avatar
It's not as good as OEM but my vote is vertex, it's what I did.
Old 03-05-2012, 04:08 PM
Bye, Bye.
Scooter's Avatar
Definitely replace.
Elvis has left the building.
Old 03-05-2012, 04:10 PM
Replace for sure. You don't want that thing falling apart while driving.
Old 03-05-2012, 04:12 PM
Weekend Mechanic
vulcan300's Avatar
Wow, thanks for the quick feedback! Now the next question is, does anyone have a sued fan housing lying around? Preferably a 930.106.102.4R?
I checked out the Vertex, and the price isn't too bad. Would it be plug and play with my existing fan and alternator? Are there any tricks to removing the alternator from the fan housing? It seemed to be pretty fused, but I didn't try too hard to separate the pieces since I was hoping to re-use the housing.
J
Old 03-05-2012, 05:20 PM
tazzieman's Avatar
J
When the vibrations take out the fan blades , that will be an expensive lesson!
Try here 911 fan housing | eBay
and post on the WTB section of the forum.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 03-05-2012, 05:38 PM
6 cylinder symphony
I did the Vertex swap last year. The good is that it bolts right in. It's aluminum, and probably more durable than the stock magnesium housing. And new ones are NLA.
The bad - it's a rough sand casting. I painted mine flat black - it looks OK. To get the alternator to sit right in the housing, I did a lot of work with a dremel and steel wool, so it would fit correctly. Finally - if it matters - the original ones are magnesium and very very light. Lighter than the vertex replacement.
The verdict - it needs a little work for correct fitment with the alternator, but it's really the only game in town.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 03-05-2012, 05:49 PM
David's Avatar
I'd stay away from used since if it's not cracked it will be soon. Unfortunately magnesium is not known for long life.
Old 03-06-2012, 05:19 AM
Deadeye's Avatar
yes!
Old 03-06-2012, 05:42 AM
