Goodie
Ball Joint Nut Question
'80SC ball joint nut...how do you tighten it? Obviously there's a special socket to fit the four cut-outs, but is there any other method?
Also, I believe it calls for a torque of qround 180 ft lbs. Locktite? Confirm please?
Thanks for your suggestions!
Old 03-06-2012, 04:26 PM
tazzieman's Avatar
The factory tool or your home made version (large socket + careful grinding) - but no other method I know of to get the right torque. Locktite cannot hurt, but not to be used as a substitute for the correct torque. You do not want this part to give way!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 03-06-2012, 04:42 PM
mspirito's Avatar
Use the search function
pete3799's Avatar
A dodge (mine was for a 1986 year) 4x4 front axle nut socket sort of fits(mine kept slipping off) but the real deal sold by our host works a lot better.
I didn't use locktite on mine.
Pete
79 911SC RoW
Old 03-06-2012, 04:46 PM
dshepp806's Avatar
There does exist a special tool for the nut,......just used one recently (from our host),..but was (unfortunately) set back at a mechanic's attempt at removal, using the tool, under air pressure...didn't take long to grind the keys off,......it truly IS an install-only tool....yet I've not yet tried it.....I have , however, used a damned pipe wrench with one helluva' extension,..on the removal AND install,........calling it a day,..swearing that I'd have it properly checked when she's in for some upcoming work at the professional wrenches' hands,..taking time to "mark" the castlenut position with both white-out and sharpie,..allowing me to "see" if any movements exist. I do belive my torque (1989) is spec'd at 185 ft-lbs.
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-06-2012, 04:48 PM
