please tell me there is a trick
try in to put an intake back on a 74 with the engine in,help
Member 911 Anonymous
how or when was it removed?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Fleabit peanut monkey
They say the older CIS's are easier to install.
I would say to install the runners into the airbox with the rubber gaskets on loosely before dropping it down onto the heads. Spin the clamps on the rubber boots so they can be accessed with a phillips screwdriver when the setup goes onto the engine. You will still have the hassles of the intake to head nuts that require some nifty 1/4 inch swivels on your sockets for the ones in the far back. Last edited by Bob Kontak; 03-06-2012 at 02:46 PM.. |
Lower the engine slightly. Dont loosen thinking you can tighten the runners for 5 and 6 in the car.
Bruce |
thanx folks,ill try Bobs plan ,I dont want to lower engine if poss
I did a 74 without lowering the engine. No very difficult. Just slide the rubber boots up onto the air box then slide them over to the intakes when un position, tighten from the front of the car to the posterior. Just go easy no big deal
Mixer - there are no worries about dropping the engine a few inches. It is a piece of cake. |
Ive had to pull the unit out again,to replace the two hoses under the airbox,the large one just crumbled.It looked fine when I cleaned the engine,but when I moved it ,it was stiff and it cracked.
(note to self "always replace any hose no mater how good it looks") |
