-   -   converting a 911 to 964 (http://forums.pelicanparts.com/porsche-911-technical-forum/663957-converting-911-964-a.html)
luyckxglen 03-08-2012 11:08 AM
Hi guys , im new to porsche and on this forum.
I bought a 86 coupe 911 but i like to change the rear and front fender to one of a 964.
Some people here who can give me some advice and people who allready done this.
Is it much of a modification?
greetz
80-911SC 03-08-2012 11:26 AM
mine was done when i got it ...Better Bodies kit .. no fender work needed .. its front bumper, rear bumper and rear lights and rocker covers .. the rear light invole some cutting and modification .. completed by the bolt in of H5 style front lights ... some go to the far end and do the interior nut mine is just exterior ...
http://forums.pelicanparts.com/uploa...1331234725.jpg
http://forums.pelicanparts.com/uploa...1331234751.jpg
its a 1980 SC
luyckxglen 03-08-2012 11:37 AM
ye thats the look i want.. but what you mean with cutting for the rear light? and i just buy 964 bumpers and it fits?
greetz
darrin 03-08-2012 12:07 PM
PLEASE don't take this the wrong way, but are you sure this is the appropriate first step for your new '86 coupe? It took me quite some time and quite a bit of $$$ to get my 86 targa mechanically sorted out. During the process, I learned firsthand the concept that every 911 is a $20k+ car.
Specifically, many carreras (mine included) suffer from premature valve guide wear, necessitating an overhaul of the engine's top end ($5-6k). Similarly, many 915 transmissions may require rebuilds to address grinding issues, etc. (or at the very least coupler rebuilds/alignments). Most of the suspension bushings may require replacement, etc.
Bottom line, you might want to seriously consider getting your new 911 mechanically sorted and driving like new before starting to make cosmetic changes. Especially since changing a 911's cosmetics to a non-original state generally decreases our cars' value. Put another way, if you're heart's set on the 964 look, you might want to consider flipping your carrera and simply buying a 964, which can be had fairly cheap these days and would offer you abs, air bags, a more powerful 3.6 liter motor, a g50 transmission and a working retractable rear spoiler.
Food for thought
don gilbert 03-08-2012 12:17 PM
I would do it, lot of weight savings, esp on the rear which is where you want to save weight. save the old bumpers, they practicaly come off as a whole assy.http://forums.pelicanparts.com/uploa...1331237726.jpg
http://forums.pelicanparts.com/uploa...1331237842.jpg
jmod 03-08-2012 12:21 PM
Hi,
Here is a recent thread with some of the issues.
http://forums.pelicanparts.com/porsche-911-technical-forum/620617-c2-bumpers-82-sc.html
The degree of difficulty depends on whether you want to use OEM parts (need some fabrication) or aftermarket (some fab work done already).
80-911SC 03-08-2012 07:33 PM
DonGilbert ... that is a sick car .. I remember the first time I saw it after your paint ...
The light mounts for the rear are different and so is the reflector mount ... they have kits you can buy that make it easier ... and as gilbert said the weight savings is drastic .. Just losing the bumperets if they are the us style are almost 40lbs then lose the weight of the bumper and you just lost a chunk ... I had the weight of my car somewhere but I think it was like 250 + lbs lighter than it came from the factory which by the conversion of weight to HP makes a BIG difference .. the PO also got the C4 style "cup" wheels exterior wise mine can fool a lot from 10 ft .. I have had people look under to ensure I had torsion bars when I told them it was an SC >>>>
Front easy .. rear bumper easy ... rims just buy .. headlights just buy ... tail and reflector that's the time involver .........
80-911SC 03-08-2012 07:39 PM
Originally Posted by jmod (Post 6609392)
Hi,
I heard somewhere that you can use the rear shocks for the front bumper if you go factory and the fab rear up ... but ...
Also remember ... it is your car .. make it make you happy .. I just bought another Porsche .. a 914 this time and I drove it a whole 120 miles and about 95 of that was the way home ... then it went in the garage and now has the rear lights and the trunk torn apart and then its on to fixing a few cracks at the flare attachment points ...
Kevin Stewart 03-08-2012 09:22 PM
some companies sell the rear bumper cap that matches your stock tail lights, put the rear heat shield in. I love mine also, Kevinhttp://forums.pelicanparts.com/uploa...1331270519.jpg
jmod 03-09-2012 02:48 AM
It also depends on whether or not you want to run the front fog lights or the brake ducts. On my SC the front shocks ended up fouling the fog lights, so I had to work around it. I used the front shocks on the rear bumper.
Here is my version.
http://forums.pelicanparts.com/uploa...1331290034.jpg
80-911SC 03-09-2012 03:18 AM
Very nice Jim ... I do like the looks with the lights ... I have the ducts .. and due to the new additions I guess I will wait longer to look at doing the fogs ....
jmod 03-09-2012 04:32 AM
Thanks. The left hand side fog light is a pain to install. There is so much going on with the inner bumper and washer tank that I had to install it from the front. Everything works, fog lights and head light washers.
haasfogle 03-09-2012 04:32 AM
i have a full set of rear lights in good shape that i am not going to need. also have a set of H5's but each has a chip in the glass. PM me if you want to make offer.
cheers, haas
luyckxglen 03-09-2012 08:36 AM
okay lil update my engine just hade a maintance and it has e G50 gearbox so im guessing it can take some more miles..
Now for the conversion i really want it.
But i was thinking of taking oem parts not fake..
And if i get it i can use airducts in the front bumper and keep those crashshocks?
luyckxglen 03-09-2012 08:44 AM
somebody have more pics of a conversion? like what to do with those crashshock?
greetz
Dirk Diggler 03-09-2012 09:26 AM
IHMO, I wouldn't do that kind of conversion. Buying the parts,hack the rear end, having them painted all this will cost you $$$ and at the end you still left with a "old" suspension, less powerful engine. I would sell the Carrera and buy a 964 instead....
Just my 2cents
luyckxglen 03-09-2012 09:48 AM
car wil be painted anyways and who says i aint upgrading the suspension? 3.2l is good enuf for me and i want to keep an oldtimer cause its cheap to ensure etc
Jbp 03-09-2012 10:35 AM
Hi
Mine is a 911s -74 with 965 style. 3.3t,sc cams,k27.930g.box.
http://forums.pelicanparts.com/uploa...1331318007.jpg
http://forums.pelicanparts.com/uploa...1331318076.jpg
Jocke.
wayner 03-09-2012 10:39 AM
How about IROC style bumpers?
luyckxglen 03-09-2012 11:16 AM
Originally Posted by Jbp (Post 6611858)
Hi
Jocke.
verry nice thats how i want mine to look like but allso with the 964 engine cover with elektric spoiler.
Got any tips on how to mount the fenders?
Dirk Diggler 03-09-2012 12:15 PM
Still wouldn't do it :). But we are all grown up and enjoy our cars. Good luck and keep us in the loop.
don gilbert 03-09-2012 04:58 PM
http://forums.pelicanparts.com/uploa...1331341076.jpg
with elec spoiler
Mia911 03-09-2012 05:54 PM
Here's mine 1974 911s w/ 3.6
http://i516.photobucket.com/albums/u...n/56da1255.png
http://i516.photobucket.com/albums/u...n/84030ba7.png
http://i516.photobucket.com/albums/u...n/bc58eb01.png
http://i516.photobucket.com/albums/u...n/a90b2d0e.png
Mia911 03-09-2012 06:03 PM
http://i516.photobucket.com/albums/u...n/photo-37.jpg
http://i516.photobucket.com/albums/u...ohnson/i-1.jpg
Here is d rear
http://i516.photobucket.com/albums/u...n/2451a3df.png
This is how I bought it..
luyckxglen 03-10-2012 01:38 AM
wow massive change , but anybody with some pic how you changed it? of some advice , lose the origi shocks in the front? and just buy that aluminum piece thats behind the fender?
Jbp 03-10-2012 10:40 AM
Front fenders are 930 and rear is welded.
Aal steel.
Jocke.
dw1 03-10-2012 11:47 AM
Here is an OUTSTANDING update / conversion
It had be seriously thinking about an update....
http://forums.pelicanparts.com/porsche-911-technical-forum/478205-pics-my-car-local-car-show.html#post4703099 (by supercarrera82)
http://forums.pelicanparts.com/uploa...1331479163.jpg
luyckxglen 03-11-2012 05:00 AM
verry nice man
tanmanbgoh 03-11-2012 05:54 AM
bought it this wayhttp://forums.pelicanparts.com/uploa...1331470447.jpg
luyckxglen 03-13-2012 11:11 AM
guys what exhaust do you use for dual outlet? and post more pics of the back fender. do you use a rubber between the fender and the body?
80-911SC 03-13-2012 12:32 PM
on mine its a modified stock single out at the drivers side .. thats the give away on mine ..
luyckxglen 03-14-2012 11:32 AM
ye im looking for a 2 out that fits the 964 rearfender
Porsche Doc 03-14-2012 11:41 AM
If ya need a Factory rear bumper...
I have a Very Nice one!
luyckxglen 03-14-2012 01:38 PM
no bumpers needed only an exhaust , but im from belgium soo shipping is a pain in the butt :)
luyckxglen 03-16-2012 09:44 AM
damn guys i need some help i cant find a dual exhaust that fits my conversion bumper 964
greetz
Fast82930 03-16-2012 10:41 AM
Many years ago I had B&B make me a single in twin out system for my 930 with 964 bumpers. You’re probably better off having a muffler shop build you something custom. Seems a more common approach these days is to route the wastegate to an exhaust tip on the driver side with single in/out muffler to the passenger side.
My current setup is more about saving weight...
http://forums.pelicanparts.com/uploa...1331919578.jpg
luyckxglen 03-17-2012 01:51 AM
ye i was thinking of adjusting some kind of muffler , you know dansk has one with 1 in 2 out but these come to wide.. wont find apperently
Kevin Stewart 03-17-2012 10:30 AM
the muffler is just a big chamber, you can cut a whole for an outlet in the opposite side, reduce the tail pipe to 2-1/2 or 2-1/4, the b&b stuff you can see the imprint on the muffler where the tail pipe should be cut, Kevin
luyckxglen 03-17-2012 11:24 AM
ye no you dont understand , my read bumper has 2 holes in it.. i just need a muffler with 2 outletpipes :)
cain 03-17-2012 11:24 AM
Theres alot of great looking cars in this thread
Cheers
Cain
