NO LIFT's Avatar
Please update me with battery ideas
I've read over these threads:
another battery install thread
Light weight battery question.
My '88 needs a battery.
Like many others, I had an Optima, but am intrigued with the idea of a light weight/lower cost solution.
Does anyone have any recent install/ideas/solutions that they can share?
Thanks!
2003 996 Carrera
gone but not forgotten '88Carrera '96 993 '89 951
Old 02-23-2012, 06:44 AM
Send a message via AIM to NoLift911
Yup - get a lighter weight one. Move it to the smugglers box and cut down on alot of extra cable and weight in the process and clean up the trunk.
It is a pretty simple process - lots of lightweight options out there but the cheapest I found was the "Miata" battery which was specifically made for the WEVO battery box - fits great.
Jeff
Old 02-23-2012, 07:34 AM
Dublinoh's Avatar
Check out Braille brand for more options, Braille B3121 under 22 lbs, but if you are not racing will the weight savings make up for a car that won't start some night? I decided on B7548 945 cold crank amps, 45 lbs, installs without an adapter, sealed no leak technology (like Optima), $235 free shipping ebay.
Old 02-23-2012, 09:08 AM
Administrator
Jack Olsen's Avatar
I'm still running a wheelchair battery.
From 2006 to 2009, I used a 19 lb one that cost $43. It lost its charge during an extended period of work on the car where it sat while fully discharged (my fault). For the last three years, I've used a slightly heavier one (25 lb). It's going stron, and cost me $61 -- although the price has now gone up to $69.
Universal UB12350-AGM
Old 02-23-2012, 12:39 PM
River Rat
Dave 86 930 Fl's Avatar
I've been running an Odyssey 925 for 3 years with no issues. I utilized the stock location (low cog) rather than the smuggler box. Mount is from Rennline.
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 02-23-2012, 12:47 PM
NO LIFT's Avatar
Thanks for the replies and advice!
I'm thinking I'll stick with original battery location because my strut brace is in the way of the smuggler's box and I utilize a battery tendser.
Where to get a battery box for a smaller battery?
2003 996 Carrera
Old 02-24-2012, 06:21 AM
Dublinoh's Avatar
Our host, search "battery mount"
Old 02-24-2012, 06:38 AM
River Rat
Rennline
Old 02-24-2012, 07:00 AM
Do you really save that much from moving the battery a foot or two to the smugglers box?
Old 03-06-2012, 05:59 PM
AutoBahned
RWebb's Avatar
that much of what?
the wt. savings from a shorter cable is tiny
the car will spin faster tho...
Old 03-06-2012, 06:21 PM
Save that much weight.....
Old 03-06-2012, 06:30 PM
AutoBahned
RWebb's Avatar
no worthwhile wt. savings - the real issue is the change to the polar moment
Old 03-06-2012, 08:19 PM
The weight savings would be nice if you used a voltphreaks battery and mounted it in engine compartment. That would use a lot less cable plus savings of a 5 pound batter
Old 03-06-2012, 08:28 PM
Here is a company that is making big waves in the fast street car and drag scene.
Lithium Pros 12-Volt Lithium Batteries - JEGS
Old 03-06-2012, 08:54 PM
AutoBahned
RWebb's Avatar
Porsche has a nice one they'll sell you too...
or you could hold out for Li-air technology
Old 03-06-2012, 09:34 PM
Gary.H's Avatar
Braille 14115 in my '82 SC 11.5 lbs
'82 911 SC - Slightly modified (not nearly light enough, 1130kg on 1/4 tank !) - 964 cams 232.1 bhp
Old 03-09-2012, 01:48 PM
You can see the reason for everyone going to the AGM batteries in the Photo above. All that corrosion due to leaking battery acid. It is absolutely necessary to clean that up and make sure it hasn't eaten up your suspension pan.
Also not a good idea to leave the pos terminal completely uncovered.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 03-09-2012, 01:58 PM
Gary.H's Avatar
True, but almost certainly not the worst aspect of my car - lol
Old 03-09-2012, 02:23 PM
I second the Odyssey battery, good stuff.
Old 03-09-2012, 02:44 PM
Gary.H's Avatar
Bit heavy though at 11.5 lbs I may try the Braille 106 @ 6.6 lbs !
Old 03-09-2012, 02:47 PM
