Canyon Runner
70SC's Avatar
915 lsd ?
I have a 915 trans # 915/ 61/ 12 / 7770 . It should be a LSD . But when i turn the rear wheel the other wheel turns the opposite direction. This means open diff correct ?!?!
Old 03-12-2012, 08:58 AM
brooklyn ny 11234
930 slant nose's Avatar
yup
Old 03-12-2012, 08:59 AM
Canyon Runner
70SC's Avatar
I guess i am part of the 40 % that doesn't have LSD with a 12 in the trans #
Old 03-12-2012, 09:02 AM
Mitch Leland's Avatar
70SC,
Do you know if you have the original trans-axle in the car? In my case someone replaced my trans-axle with a non LSD rear end. I've been told that people will swap out the tans-axles to get the LSD...
Mitch Leland
"03" 996 C2S-LS3 V8-480 HP
"84" 911 Turbo Look-Sold w/ found memories
Old 03-12-2012, 09:09 AM
Canyon Runner
70SC's Avatar
Hi Mitch . as you can see from my name 70 SC . My car is a 70 with a 81 SC motor & trans.
Old 03-12-2012, 09:41 AM
Lsd...
The SC went right by me... What a great combination.
Thanks,
Mitch Leland
Old 03-12-2012, 12:00 PM
Bill Verburg's Avatar
Not necessarily. It only means that the lsd, if present, isn't functioning as a lsd at light load.
There could be several reasons for this,
most likely, the lsd plates are so worn that there is little or no preload left and/or the worn friction plates are no longer grabbing as they should
the lsd could have intentionally been setup w/ little or no preload, which causes it to be less effective w/o a load relying instead on the ramps to force the plates together under load
Bill Verburg
Old 03-12-2012, 01:20 PM
djcdmv's Avatar
Isn't it true that the trans should be in neutral for this test. If it is in gear, then the other wheel will turn in the opposite direction.
Dave
Black 1985 911 Carrera M491
Old 03-12-2012, 01:28 PM
Canyon Runner
70SC's Avatar
A+ Yes in neutral
Old 03-12-2012, 04:17 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 in Neutral Both Wheels Spinning = LSD, just checked.
'85 Carrera Targa
PCA/POC
Old 03-12-2012, 07:43 PM
