Carrera 3.2 No-Start
I just had some service performed on my 3.2, and checked for an intermittent bouncing idle. I had already checked/cleaned the idle control valve, but it was actuating fine and clicking prior, and I've had the issue since so it wasn't that. My shop indicated that the car was fine when they tested it multiple times. It went to a bodyshop immediately afterwards to have the fuel tank refinished and some trunk corrosion remediated and refinished, and a couple of other minor cosmetic issues sorted out. I went to pick it up yesterday, and it looked great and I was super excited since I've been without the car for 5-6 weeks. I went to leave the bodyshop, and no start. Crazy, because they had just moved the car, and moved it multiple times when they had it, and it never failed to start for them. It cranks but not firing, and I couldn't tell if it wasn't getting spark or fuel. I had a spare DME relay (always keep on in the car) and it did exactly the same thing. The car does have a SW chip and M&K cat bypass and sport muffler. Anyway, the car got towed back to my tech's shop and no updates yet. I'm wondering if it's something related to removing the tank, but that wouldn't explain being able to move it around prior to me coming to pick it up.
2018 Porsche 911 GT3 manual 1984 Porsche 911 Carrera Targa 2021 Porsche Macan GTS 2018 BMW R1200GS Adventure Rallye 2020 Ducati Scrambler 1100 Sport Pro |
Strange behaviour.
First - check for a spark with another spare spark plug in a ignition cable and givin it ground contact, let a helper crank the engine. If there's a spark check next for fuel spray from one of the injectors. I suppose one of them is missing. Could be a coincidence that this issue came up after restoring the fuel tank. Possible is dirt in the fuel pump or the injection system due to the fue tank restauration works. Or either the fuel pump, ignition coil or even the tdc or rpm sensor died suddenly... Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
It turned out that the bracket mounting the fuel pump was tight enough to be squeezing the housing, eventually causing it to fail. I've been having intermittent bouncing idle and dying when pushing in the clutch, and my shop couldn't find the issue prior since it ran perfectly when they had it. It has been fine since I picked it up Friday, so I'm hoping that was an issue related to the fuel pump.
Thanks for posting the answer to your issue. So often someone comes to the board posts a question, lots of suggestions are suggested, and the OP never returns to say what the issues was.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
to be honest with you..it really sound like there was a clamp on the fuel line from the fuel tank and the body shop forgot to remove it...i have seen this one before..just an idea ...glad it is running now for you..can we see the beast?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
looks great....
Ivan
